Can check this oem out.
I feel your pain brotherā¦and then you post on a board and all these people chime in with their bullshit about itās not the companies fault and every other reason when they are not in the driverās seat themselvesā¦if the shoe was on the other foot
Iām reasonable and realize that things are sometimes out of said companies control but some companies out and out just lie for the saleā¦that is bad business in regards to holding on to repeat customersā¦but their reasoning is ā thereās always another fish ā
I find that unethical and unacceptable
Like a mexican jumping bean⦠kind ofā¦rip one out of a phone ![]()
Definitely need to try those 2 in combo
Z axis and x axisā¦
Hopefully they are powerful and also requiring less power to driveā¦
I wanna feel the drummer sitting in my iem and kicking the kick drum in my ears ![]()
I remember you wanting a 20" sub
I can try to give a 20mm dd in ears at best ![]()
2x14.2mm =~20mm performance ish.
Two ASG 2.5s stuffed in each earā¦Iām downā¦where do I sign
Youāll probably lose your patience with me tho tbh ![]()
Itās 3699sgd (around 2.7k$)
Prolly wanna wait until Chris drops the review once i send his unit.
How much labor in one unitā¦if you donāt mind me asking
Labour? My charges for labour, idk
Iām barely making almost a 1000sgd (800~900 ish) honestly and I got debts to payā¦
Itās going 25 units for the first run. 3 ordered so farā¦
From r & d to design , tuning, assembly and finish. All done by me. I weave the cable as well. Itās custom wired. Itās got monobass so true 2.1 experience. Iām planning to break subbass boost graph completely so expect 30db boost ig ![]()
I believe it isā¦works out of his houseā¦maybe not where he warehouses though
Who doesnātā¦
thatās not a bass shelfā¦thatās aā¦
Graphs are⦠deceiving.
The monobass makes it even cleaner. Itās kinda a rudimentary crossfeed as wellā¦
It centers the bass giving it a much cleaner, deeper and stronger bass replay.
Each side has both channels only for bass. Iāve even wired them such that even if you switch the cable sides, the LR audio will still play correctly ![]()
thereās always room in my house for another IEMā¦all are welcomeā¦my wife is oblivious to what I spend
if sheād knowā¦Iād be sleeping in the hoosegowā¦or the outhouseā¦well maybe not the hoosegowā¦but definitely the outhouse
Iāve had my eye on the HCK Topguy..Iām a sucker for single DDs..have several and if I had to pick one type of IEM tech for life..it would be the single DD..simple old tech that just works for most of my library
Strangely enough Steven (Z) just did a review..very interested
I like single dd too, recently Iāve only heard people hyping about the nightjar singularity tho. I might have a plan down the line, i intend to make a special single dd, probably something like the s15 (planar+pr) but better. PR isnāt an active driver so itās still single dd
. Im conceptualizing a magic here. Even my current iem was a magical thought which slowly took form over the 1 year Iāve been working on it.
The single dd, Iām imagining it to be a mix of something like the singularity and monarch mk2/3 probably?
Combo of awesome bass and tech, pushing the limits of a single dd⦠Thatās the ultimate goal.
My current daily driver is FAudio dark sky. I used to have hola and z300ā¦
Hola is dead, z300 is lost. ![]()
Dont bother with PR in iemsā¦complete meme.
The S15 āPRā is more like the HDSS tech.
Excelenteā¦people get too hung up on techā¦if I put a tin can with a string in my ear and it sounds goodā¦thatās all I need
The Original MiM Dark Magician is an example of what can be achieved with the tried and true single DD config, as is SoftEars Twilight.
So trueā¦Twilight is magnificoā¦this whole journey manufacturers have taken in recent years is rather ridiculousā¦but some people have FOMO
and tech sellsā¦evidently
