Basshead IEM recs
Lol, i was actually considering the Fan because 1DD
What are you waiting for? Buy 2, so you won’t have same issue as @nymz with Teas as QC has become questionable now
I own the ex800st, and ues you can get a good/ perfect seal. I use the azla sedna earfirlights and the xelastics. The one thing I honestly do hate with a passion is the odd fit . The shell in which the driver is housed sticks out . You could also use foam tips if that’s your thing. If you could get over the odd fit. I recommend the ex800st. Unfortunately I havent listened to the ex1000. Have you looked into the Mjƶlnir Thors I also own those and they are a great bassy set.
I had the feeling about QC from some comments on head-fi
The EX800ST (tape or EQ) is more suited as a basshead iem than the EX1000. (EX1000 is the better iem though.)
The ex800st tape mod is a dangerous basshead. In my opinion it doesnt need the mod. Imaging and detail are great with this warmer iem. From what I have heared / read the ex1000 is brighter . So like everything audio , it is subjective to preference. So as a basshead iem I think the ex800st stands tall.
If you want a basshead iem (bass quantity over quality), then you either need the tape mod or eq with the ex800st.
The iem provides nice bass/subbass as is. If you want extra bass then the mod is definitely needed. Other than that the bass is basshead certified, no mod required.
not in stock, not at all.
Perhaps stock is enough for him :smiley:
Is this good for opera, igor?
Did you post that graph because you believe what the graph shows? In that case the ex800st have zero bass.
One thing I strongly recommend, dont ride a bike while listening to music on these. They suck ball . The seel cant stop the wind. Riding in the bus as and walking are good just not the forces of the wind.
Just saying !
Perfect
Rec for basshead IEM: Intime Sora Light 2019
Sorry for resurrecting an old post, but have you found the Cascades IEMS?
I really do like how the Cascades sound. I have read that a lot of people compare them to the Vega. Some people say they are more similar to the Dorado. I don’t know if they are similar to the Z1R.
On the Campfire market they have B-stock Vegas for 499$, really tempted, but then I always think that I should not buy new stuff, and enjoy what I already have… Then the Z1R start to click again in my mind, just the need to try them… It is very probable that I end buying them. Now I am on saving mode…
I disagree. It doesn’t sound bloated sounds realistic and awesome to me. Like car audio
TiandirenheTD09 , this is a real bass beast :love_you_gesture:
