I may have found the issue. I suspect the cable I use merges both L/R channels into one stereo mix so of course it wouldnât be able to locate any audiospatial information or sound less detailed as I described it.
I will see when I get the new cable tomorrow or Tuesday. Thanks for your patience with me lol
That will do it lol, would really destroy fidelity
Ok, that was definitely it and everything sounds fine now. Still unsure if I hear a difference between amp and no amp but at least itâs not worse like before. Next step is a proper DAC I guess
Thatâs good that it was fixed lol. So an amp isnât going to be immediately night and day, so as you spend time with the amp, and then after a few days go back to without an amp, see if you notice any differences. A dac will upgrade it further, but again not a night and day difference
You know youâre an audiophile when your autocorrect thinks you meant âdacâ instead of âdayâ
Fixed it lol, that actually was just a mistype, I donât have autocorrect on my pc lol
Oh, OKâŠ
You know youâre an audiophile when your brain says âdayâ and your fingers type âdacâ
howâs that?
Thatâs more accurate lol
Has anyone tried this with the SMSL SP200? Iâm thinking of getting a pair if my amp con power it properly.
same question, but if they donât sound good on the 789, I doubt theyâll sound good on the sp200. basically the same amp
So from my experience the sp200 has a better single ended out than the 789 so imo it would be better, but I personally wouldnât recommend a thx amp in general
It can power it just fine, but I donât that thatâs a good match sound wise imo
Yes, I have. I found the treble to be very sharp. The spatial presentation was ok, but the 880 sounds better on the Asgard 3 than the SP200 by a fair margin, IMO.
Also to clarify from those coming from the z review, they are powered just fine off of a magni 3+ or liquid spark, both are great amps for the headphone imo. Other amps a bit more that I like as pairings are the asgard 3 and the jds el amp ii.
They run fine off a basx a100 for sure, but you really donât need a speaker amp whatsoever, and also it doesnât sound as good as a well paired headphone amp for the same or less money imo
Thanks for the info, good to know we donât have to spend quite that much lol.
I donât see quite where Z is coming from by dismissing so many lower-end amps. To my ears, these sound fantastic on a Darkvoice, with qualities that surpass a 6xx and other similar-priced headphones. I think they particularly benefit from using a OTL tube amp like the Darkvoice or Little Dot mk.II, as opposed to a solid-state amp.
Yeah, I think heâs really should be starting to realize how poor of an amp thx is (he most likely isnât unfortunately though), and also isnât realizing that the cheaper amps are actually bettering the thx (so in his mind if the thx canât the amps lower than the price of a thx canât either?). I guess if you want to ignore the flaws of an amp, just saying the headphone is stupidly demanding and have to be used with a speaker amp works lol
Also the 880 600 do take well to a tube, itâs a pretty nice pairing
Yes. I agree the 880 is the standard-bearer in several sound categories in its price range. And also agree, they sound particularly good on a tube amp with quality tubes. The Darkvoice + 880 has become my current go-to for classical music and gaming.
I also agree with this. The Senn 600 series is often lauded for its midrange timbre. Maybe thatâs true for the 600 itself, but the 6xx often becomes shouty and is easy to overload in the mids. When it has the resolution and isnât shouty, its mids do sound wonderful. But when the mids get busy it lacks the resolution to separate everything. The DT880 rarely skips a beat. No shout. And only in extremely rare circumstances have I felt it might be breaking timbre in the mids.
I find this to be true when paired with the darkvoice (I honestly just donât think those two jive) but the 6xx 650 is really nice and smooth on the liquid spark and xd05 for examples. Itâs been awhile but I remember the 600 actually being the more mid forward âshoutyâ of the two(on budget amps and hopefully Iâm remembering that correctly). I did just buy a 600 again so I look forward to comparing the two again.
Iâm going to mostly agree with you here. After initially reading this comment I went back and did some listening to the 6XX on my Asgard. It sounded pretty nice overall. I still did detect a hint of shout here and there. Some acid tests for my ears are the vocals of Steven Wilson (both solo and from Porcupine Tree) and Lenny Kravitz. For whatever reason, if thereâs shout, my ears will hear it on their voices. There was just trace of shout with Wilson, more noticeable with Kravitz on the Asgard + 6XX. I did notice the timbre breaking again toward the end of Wilsonâs track âTo The Boneâ, but less so than Iâve noticed with the 6XX in the past.
I also checked the 6XX on an Atom. And WOW. Shout. Shout. Let it all out! That is a thing I can do without (had to stick that in there, too perfect to ignore
). Same deal when I switched the 6XX back to the Darkvoice. Kravitz in particular just had all kinds of shoutiness and honkiness going on. Iâll remind everyone again that my ears are pretty sensitive in that ~1K region and Iâm pretty confident I perceive shoutiness before most. So, I think I agree with you. Most will find an amp that the 6XX does have those silky mids itâs lauded for. Thanks for dropping that comment.
Just to make sure we get this back to being a DT880 thread, I do not notice any of those midrange issues - shouty, or honky, or lack of resolution - on any of those amps with the DT880. To my ear, the 880 just does a better job there.
