Can someone tell me how the Ninja edition is different (sound-wise)?
Itās going to be a bit brighter sounding because of the black pads being brighter
Gotcha thanks.
Would you say that itās brighter than either of the pads with dt1990s?
I would say itās warmer and more relaxed than the 1990 (the mk2 at least)
Thanks there have been some deals recently and Iām hoping they last a few extra weeks for me to be able to pick a pair up. Still very curious on them lol.
Yes they are on sale. The ninja black lowest price was 600$ now it is 650$.( Edited: ebay have them for 600$).
Silver T1.2nd:
https://www.focuscamera.com/beyerdynamic-713805-t1-generation-2-headphones-black-silver.html
Ninja black T1.2nd:
The T1ās are one of the few headphones iām interested in (HEDDphone too) I liked the mk1 but not heard mk2 is there much difference in the over all sound delivery?
I always wanted to try the T1.1st gen. People say the T1.2nd is more warm with more bass and controlled treble, but it lose sound stage and openness.
Then iām looking for the mk1 thank you ![]()
Hey, I guess this is my final decider, so I was partially intrested since these are 600ohm as well, so do these take to a tube more than say the lower end 600ohm Beyers . If not which is preferable etc.(other options welcome as well, outside of sennheiser 600 series) The initial amps will contain an output transformer, tube amp, and up to several hundred ohms of output impedance etc.
I just watched a livestream earlier where they briefly mentioned the DT880ās for tube amps.
I think MON has also mentioned that these ātubeā really well.
Yes, both the 880 600 and t1 tube very well imo
Thanks for the cable links. I noticed the stock cable has 3-pole (TRS) connectors running to each earcup, but couldnāt imagine why 3 poles would be necessary (or even how they might be used). Was going to ask if anyone here was using a cable with 2-pole connectors, but your second linked cable (the one you like) has them, so I guess that answers that. ![]()
FWIW, Iāve recommended these to a friend for gaming, and was looking at Periapt cables with a sleeve matching his gaming rig color scheme. Periapt uses 2-pole connections.
ā
UPDATE: Beyerdynamic just emailed me back:
Unfortunately, we cannot authorize the use of any other cables other than our own for our headphones. The T1 has 3 pole connections for a true balanced connection to each ear cup.
Ugh. Donāt make me pull out my multimeter. And stop being so corporate. Itās a %*#@ cable, not a trade secret.
Any balanced 2 pole or even mono works, no worries from my experience
Pulled out the Fluke:
Tips are hot and ring + sleeve are essentially shorted (the sleeve-to-ground path is about 0.2 ohms less efficient for anyone keeping score). This is exactly how 2-pole mono connections are wired, so what @M0N said, confirmed by science!
I forgot, did you install the speedball as well? With the speedball I wouldnāt worry about loosing speed, but without the speedball the amp can be somewhat sloppy imo
I donāt personally feel this would be the case unfortunately
Ah yeah, a crack + hd600 is very pleasing, but wonāt have near the speed of the 95x
Iāve decided to get these over the Dt1990 Pros (for Now) Whenever they go on sale (theyāre currently over a 1000 Dollars CAD)
