does US beyerdynamics regularly stock the tygr earpads? everytime i look them up, theyâre always out of stock.
@lush theyâre just 990 black pads with the tygr foam piece instead of the standard form. best way to get would be to either email the parts department and get in their system for when they get stock or to just order the 990 pads if you didnât need the foam piece.
i canât find dt990 earpads on beyerdynamicâs store, but i found these on amazon: Amazon.com: beyerdynamic EDT 990 V Ear pad Set Velour Silver Grey : Electronics
are those it? if so thatâs good to know, thanks!
That looks like it matches the DT 990 model number: 904163
But I noticed the TYGR 300 R has a different model number: 934631
I will chime in to help here with confirmation as well
The Tygr 300r Uses the EDT 990 VB pads from the DT 990. They started selling tygrs pads separately which include the foam pieces later on though
Thinking about picking up a pair of these as my first Beyer.
you aint going to regret that!
its not the most âbeyerâ sounding beyer headphone for sure but they are damn nice I will give them that.
I am considering picking them up, because as much as Iâve started to enjoy the Harmonicdyne Zeus, theyâre not the most exciting sounding due to their lower treble and sub bass.
How is the detail on the Tygrs? How do they compare to⊠say, SHP 9500s?
I personally never found 9500 to be all that detailed but its alright. Tygrs have less treble presence and air so it may feel more enclosed though tygr is still very detailed for a more warm signature
Hi, whatâs the HSC filter?
Thatâs a High Shelf, center frequency at 10,000 Hz.
Out of curiosity, just a general question to anyone that has had these for an extended period of time. How has the cable held up over that time?
Owned mine a little over 14 months. No issues. The cable length is short enough that running a desk chair over them is going to be quite a feat. Itâs the newer beyerdynamic cable style, which is more rubbery than plasticy like their older cables.
Biggest issue i can see is major abuse or a pet getting ahold of it.
@givemebeer Thanks, I just bought me a pair I look forward to getting them.
Hello, out of curiosity, what is the durability of the ear pads for these cans? Do you notice a change in sound signature when they wear out to itâs limit? Finally, what do you recommend to replace the worn ear pads: 3rd party or OEM?
I come from a Sennheiser HD6XX, and to be frank the clamp is not doing it for me. Plus, I heard the sound changes when the pads get worn. Itâs still a great headphone - donât get me wrong - Iâve tried to bend it, but I suppose my head is simply not meant for those cans.
Edit: to elaborate, they put pressure on my jaw(?) and over time, I feel fatigued by this pressure point
Good. Iâve had beyer pads last multiple years with no issues.
I never notice until putting on new pads.
If youâre happy with OEM, stay OEM. Dekoni velours work, too.
thank you for the reply. i saw Zeosâ video where he does pad rolling on all of his Beyerdynamic headphones with Dekoni pads. I wanted the Elite Velours for comfort reasons (because I already have experience with Dekoni pads), and I was afraid of changing the sound too drastically.
As long as you keep them relatively stock or a type of velour pad you should be alright⊠though deeper thick pads like elite velour do change the sound a good amount⊠If you need stock pads on these they are known as EDT 990 VB black or rather the DT 990âs black pads in particular.
