Blon 03 hype thread
Awesome to know, thanx MON
Bass on the blons is much more fun, in general the sound is a bit much playful. T4 have better Soundstage, clarity etc
Thanx guys, im looking for a good iem, originally wanted the T2 and then sort off just left the idea and got decent cans. But i want something portable and only watched the review today. Think the Fiio BTR5 and the blon B03 is not a bad way to spend ± $150
As I am obviously having problems with the tips on these things lol, I highly recommend getting some different foam tips that fit your ears. A different wire would probably be good too, but not as important as different tips imo because the stock tips are trash imo.
I couldn’t wear them with the stock wire, the angle of the wire would lever the headphones out of my ears.
I also swapped to foam tips.
Why cant full size headphone cables be as cheap as IEM cables lol. Saw a link earlier up in the thread for cables. As far as tips I will get some foam tips. Not a big fan of silicone tips. Last pair of iem’s i tried was the AKG that came with the Samsung S8. And even they blew me away.
Haha I got those too with the S10e. The right driver is dying compared to the left though.
I have both T4 and BL-03 and they are good companions to each other.
I find that T4 works better with acoustical/classical music rather than EDM/pop, etc. due to the lack of sub-bass (compared to BL-03).
BL-03 is a good all-rounder and more “fun” but is not as detailed and clear as the T4 (instrument separation, imaging, etc).
In terms of fit, the size of the T4 is probably one of the most comfortable I’ve used in a while.
Fully agree, for me its the T2 and the BLON-03.
Thanx, thats good to know. Will get the blon B03 as it will be my first IEM. Sure it won’t disappoint
I am planning to use the SpinFit CP240s that I ordered for my BLONs, since the CP145s are a bit short on filling my ear holes which is kind of unfortunate, I hope the overall isolation would improve once it is delivered here.
I dont think i have these earphones in right. does it matter?
As long as you have a good seal and is comfortable you should be fine
well i gotta say i dont like these very much. i keep feeling like the volume isnt high enough. like parts of it are farther away. its kinda interesting though. like its recessed in the mids. idk. I like the KZ ZS10 Pro better.
From your tastes that I gather from reading your postsaybe it lacks some brightness and detail. Maybe t4’s or the kz zsx might be up you alley
If you’re looking for something similar to the Tin T4, try the QKZ VK4. Pretty similar tonality-wise and the VK4’s are $8-15. T4’s at $80-$110 are not worth in in today’s IEM market.
Does anybody have any pointers on how to extend the depth on these? I saw some people using those plastic o’rings. I’m asking because I have to push them in really far to get them to seal, but that makes the metal part of the IEMs themselves push on my ear and cause irritation. I’m thinking with o-rings they may not have to go in as far.
Well if you say so just ordered them cause they cheap will do a comparison
I don’t know, at 80 they are still pretty good. They have their own place
The thing I’m offended by is that they’re eventually going to sell these at $110 and that’s absurd. I’ll give them some slack at $80 though.
