Well so far I am not having any issues with it and it is doing me great, perhaps itâs the wire that you need to move a bit on the wire socket of the headphones. Or perhaps an aux cable that is 3.5mm male to male with a 4 pin might help alleviate that problem, and to be honest that is actually the first time I heard a problem with those headphones if the problem still persists you might want to get a replacement, perhaps a defective model.
I donât have them yet so i canât try but i plan to buy, and since i heard about this issue from multiples sources i was kinda worried
No issues with mine, but I will say I have kinda babied them after seeing the reported issues
The exact same thing happened to me and it pulled the wire that runs through the headband out too so I had a cup hanging by a thin wire with no way to push the wire through and no way to reinsert the screw.
I think CM need to work on a way to prevent the cups from turning all the way which releases the screw.
So frustrating because I got them for AU$66 on special and they sounded amazing!
Iâm now looking at more expensive alternatives such as the Audio Technical ATH-G1.
Hmmm, if might MH751s break down as the reports say. I might as well return to my M40xs if that will happen. So far though, no issues for me.
Mine have no issues either, but I am weary now
Well all things break, but as long as we take care of it as much as we can then there are no worries.
Yeah, I have always been careful of my older hifiman and the x00 headbands just to make sure lol
My only wish is that Rtings measure them so that Jaakko at AutoEq could put out EQ settings. Theyâre super comfortable, have nice isolation and sound, but I really like the frequency response that AutoEQ provides.
Did anyone notice any crosstalk issues with these? I read something about it and that person said there are a lot of people who have the issue but I havenât found many other reviews complaining about this.
Looking for a closed back headset for when my girlfriend is watching annoying tv programs in the living room while I am there too, a mic would be preferred but only if itâs detachable. Looking at the MH752 since itâs 10eur more expensive but itâs in stock.
I didnât. I have the mh751 and itâs pretty good for the price. And very comfortable.
How do these compare to the newer MH630 and MH670? (not interested in MH650)
Where can I buy a replacement cable thatâd fit the MH751? It has a weird locking connector
The cableâs fine (other than the potentiometer) but itâs too short for my desk.
I used this one here: https://smile.amazon.com/gp/product/B01N6E6KBZ
Itâs just small enough to fit inside.
As an aside - this is one of the times that I donât really âgetâ it. I know these are rebranded Takstar Pro 82s, but I needed a new gaming headset and after Z and otherâs rave reviews I got these.
Theyâre⌠good. I mean, I donât hate them, but I was really underwhelmed after how much Z hyped these as the âbest closed-back under $200â. They are very comfortable though.
Well, actually, I do believe theyâre the best closed-back for the price range (theyâre like $70-80)
One of the best under a $100 yes. Under $200 is pushing it.
A good cable replacement?
Non braided.
Also any good Peace settings?
Depends on where you live. I bought a basic rubber cable with very thin ends, I can send you a link but itâd be pointless unless you live in the Netherlands. Make sure it has the extra pin for the mic though.
I donât care about the mic I have a USB mic, I live in Italy.
I donât know you but when I turn the volume all up on the cable my left ear cup sounds more quite that the right one so I have to go back a little for them to sound even.
