I’m still in the kicking tires phase still but have been researching my potentially endgame speakers.
When I started this quest, the Buchardt S400 was the target. Since then I’ve had the chance to chat with a few reviewers who preferred the S300 mkii se so I added that one.
But then it occurred to me I’d have to go beyond my $2k soft limit. So now I’m at $4k. Once I expanded I have been sort of obsessed with the Spatial M3 Turbo S. I have no experience with OB so my first curiosity was the bass. I like a balanced sound (leaning warm) but lots of my music is bass heavy.
The system I am building will be all Odyssey amplification
Khartago (110 wpc class AB solid state with excellent current throughput).
Candela tubed line stage
Suspiro solid state phono stage
Current speakers are Focal 807v (which I like other than their bass)
My living situation will probably involve constant shrinking of my area so I had been leaning heavily toward bookshelf/stand mount so I can stay agile.
I spin vinyl, playing lots of classic punk and reggae, 80’s and 90’s alt, metal, a touch of jazz and lately a ton of experimental/power noise and black ambient/ritualistic music.
I really do NOT want to have to run subs. I’ll have the ability but I really want to avoid it.
Sorry, im not good at forums
But these have been my endgame idea for a long time. like the styling, quality and based on the lower end models (i heard the B&W 685 S2 some years ago in an audio shop and it was lovely, but couldnt afford it at that point) i would assume that i would absolutely love em. Should go and listen to their big brothers, the floorstanding version, at a local audioshop but i dont want to bother the salesman - he knows that guy like me could never afford 20k pair speakers
and damn, i thought those were under 5k a pair.. oh well..
Dynaudio Special 40s $3000
I had a listening session recently and these are quite special. Bass is very impressive for bookshelf.
Mark & Daniel Maximus Ruby Mark II $2700
These are bonkers and kinda my dream. You order from Shanghai, shipping included. Synthetic marble should be ideal to drive bass without cabinet distortion.
I’m curious about Dynaudio but have never heard any. I’d really like something that goes down into the 30’s on the low end. I’m trying to to have to resort to subs.
Mounted bookshelves going that low are few and far between. I am wary of just written specs too. Marketing buzz around spec-sheets it’s an actual thing.
If you do not want separate sub, but can accommodate a floor-standers, I’d say the Goldeanear Triton Two+ should be on your radar. They have integrated powered subs. I just auditioned them with PS Audiostellar s300 and Parasound 21 and 23. Earsplitting bang for buck. Ugly as sin.
EDIT: The review of the Triton Two+ mentions a recorded 24Hz extension (manufacturer spec sheet states 16Hz)
I can accommodate floorstanders but I’m trying to stay with stand mounts. I’m unsure of just how small of a living space I’ll end up in so I’d like to be able to adjust as needed.
I’ve looked into the Tritons and they seem to be a polarizing speaker. I’m down to hear anything really. There’s a local event coming up and several speaker manufacturers will be there so I’m hoping to get a feel for what brands do what.
Spatial will be there and since the M3 Triode Master is on my list (yep, a floor stander) I’m psyched to hear it. People running subs w/them has me worried. That’d max my budget and if I STILL need a sub…ugh. From what I have been told, rock/punk/reggae style bass is no problem but getting into Scorn style sub bass exploration is where things fall short. I’m dying to get someone to try it. I’m hoping to when I’m there.
Scorn is new for me. Industrial dub made by Napalm Death folks. Fuck me sideways. Are you trying to avoid a dedicated sub because of space? Scorn tunes are screaming for a JL Audio e110. Please don’t hate me.
Specifically the Scorn track “Look At That” off Logghi Barogghi. That insane sub bass, if speakers do that to a decent degree then they’d be good with Trepaneringsritualen, MZ.412/Nordvargr and Vril Jäger.
As for subs, I’ve read much about sealed, servo subs and well, my preamp doesn’t offer any kind of bass management so blending might be an issue.
I’m a bit of a noob on this but the JL e110 I mentioned comes with a calibration CD and you do not need any calibration from preamp. Additionally you could use a miniDSP HD to blend them correctly.
This is a 2.1 set up with Special 40s and JL e110. Makes me salivate.
at the risk of getting hated on. here we go. Have a look at Beolab 17 to me they sounded great, but those are active tho. for a normal room you don’t need a sub with those and they push a bigger sound than anything in their size. Demo it.
soundstage breaks down in bad recordings and strong s-lutes
soundstage also goes in front of the speakers and sometimes jumps toward you
can distorted with large dynamic jumps / volume
sometimes a bit muddy
bad recordings sound bad
Price is good
Special 40s
much differentiated soundstage
Resolution
If it really gets down to business, they will not lose track, the instruments stay separated
Midrange is less setback and very neutral, well above the price range
Speaker position is impossible to locate
beautiful crisp bass
loves vinyl, bad recordings never sounded so good
needs at least 200W @ 4Ohm stable (if AB solide state) for good bass
extremely demanding on the amplifier, grows tremendously with good electronics
must be far away from the wall, Soundstage grows until you reach about 1.40m
incredibly solid power handling, no cutoff needed on subs
Soundstage starts behind the speakers
These 2 speakers would also be my choice in your situation. I made a small comparison for you, since I’ve heard both. But I’m a bit biased, since I’ve been using Dynaudio Contour 1.3 mkII for ages (sonically the role model of the Special 40). I don´t know any other speakers that likes to play old vinyl and dos not always have to play very loud to sound good. Although I have already bought many other speakers, I always come back to Dynaudio. With both speakers, I would think about more stable levels and fill them with sand, if the bass should be really good.
That is not my system! That is what I aspire to have tho. But yes, it looks (and I bet it sounds) amazing.
Thanks for your informative post. I am now closer than ever on pulling the trigger on some Special 40s.
The plan is to pair them with a Wyred for Sound ST500 and the JL e110 or just with an SST Son of Ampzilla II.
The Wyred for Sound ST500 looks like a good amp, but I do not know it and have no experience with Class-D on Dynaudio. These speakers have taught me a lot, especially what difference amplifiers do make and where you must invest your money in. On my 1.3 mkII I had bad sound experiences with: Yamaha AS-700 (no bass, too weak), Rega Elex R (too weak, mids sounds unnatural), NAD C 275BEE (just not clean enough, did not make fun, the most unreliable amplifier in the world) Good partners: Vintage Japan made 1980 Technics SU-V8 (incredibly warm, beautiful and musically but unfortunately very vulnerable), Audionet SAM V2 and SAM G2 (just clean and neutral Class AB Power, the highest resolution I’ve ever heard). With Dynaudio you are best served with neutral and clean as well as powerful amplifiers, much damping cannot hurt either.
The Special 40s do not really need a LowCut, because they are extremely load-stable and Dynaudio already knows how to build their speakers (not like Buchart whose S300 explode with too much power). That’s why I would go for JL and pair it via the speaker cables, not RCA!
Interesting. Actually the Special 40’s were originally on my list but I do t have a way to hear them and they need a sub which I had been trying to avoid.
As for the s400, it’s interesting about the muddiness and also brightness you mentioned. I chatted with Thomas (& Stereo - YouTube) and he told me the s400 has a natural tweeter (ala Harbeth) vs the s300 which has a more assertive tweeter.
I’ve not read anyone describing them the way you have. That said, I’ve sort of eliminated them because I feel like they’d be an upgrade or positive side move but not an endgame move. Which is why I’d become much more high on the Spatials.
Currently, Odyssey kismet Monitors (3700 + upgrades) and spatial m3 (possibly triode Master) tip my list. Both have pros and cons obviously.
