Lol, really hope it lives up to the hype.
https://detail.tmall.com/item.htm?id=604099078511&scene=taobao_shop found it available here
Cant find the spot to translate to English, looks like „698 that is way way less than $100
top right on chrome by the star
Sweet, thanx will try
It could be nice to see a comparison between btr5 and Shanling up4. Both units looks really interesting. I wonder about their differences in performance and sound.
How does it sound compared to daps like FiiO m9 or even 11
According to zeos this thing supposedly sounds better than the M11 and Q5s, Iām skeptical of that to say the least.
Same lol, kinda skeptical
I think you can pre-order from hifigo, will be shipping this week or next week
$5 coupon code: HIFIGO5
Fiio BTR5 and Shanling UP4 with about same specs, want to the know differences in performance and sound
i just bought it but got a few questionsā¦
I dont have a car but trying to understand car mode - is that just for charging so that it doesnt suck juice when car is off? or am i missing something here bluetooth from phone to car stereo, no need for btr5??
I have a Oppo-Ha2, how does this compare to it in terms of headphone driving power and DAC sound?
Should I get rid of my Fiio M6 and use my iphone X with Btr5 and does the fiio IOS app allow to play flac? (assume its gonna just be aac, no ldac here)?
Anyone tested the mic ? wonder how effective it is for calls and conference ones too.
thanks!
So the car thing, itās for ur btr5 to automatically power off and save battery when ur not using it (ie, when your car turns off) and the need to use the btr5 is just to add Bluetooth to ur car, or a better sounding bluetooth.
Not sure about your device,
And NO I suggest you keep the fiio m6 because iPhones still canāt play LDAC or a good Bluetooth codec. Not saying itās a waste to use the btr5 with an iPhone but itās certainly a shame. (unless you donāt hear a noticeable difference in quality and find it more convinient)
Havenāt tested it obviously BUT I had seen a review where they mentioned that they put focus on the mikes and used basically the same mikes you see on smartphones! So itās looking quite promising
this is so expensive compared to my local price, post forex conversion
Z said that it sounds the same as the M11 ?? I donāt believe it oO
Itās so small and only 100 dollars wtf
no he said it sounded better than the m11, on multiple live streams over the past weekā¦
Kinda skeptical on that one lol
just got it - handsome looking thing. Easy to use, testing ongoing.
Wonder how this compares to a Audioquest Cobaltā¦
How does it work as a usb dac/amp?
If itās like the Btr1k and the btr3 you turn it on and just plug it in with an adapter
