i was able to try my sennheiser ie 600 with other eartips today before i use their own foamtips that was in the box but tried them with foamtips from comply and wow what a better sound i have with those
yeah the stock ear trips are notoriously bad. I am currently running Azla Sednaearfits but I got some more tips en route to try on mine
What do you think about the sedena ?
I have also ordered final audio silicone
They Azlas are super sticky and mold to the ear canals really well. Final audio E series are my favorite but they don’t fit all of my IEMs.
Has antone tried spinfit eartips are they good
And do someone have a good eq settings for rock music for the fiio they can share
No, I just have the regular Azla sednaearfit Black (not light). I was using Senn IE Pro tips before but switched to those because of the deep insertion they offer. The IE600 has a shorter nozzle so I need a longer tip.
Having said that I can’t speak to their SQ because I also put a tanya filter on the nozzle to dampen the upper mids. Bass is tight and punchy though and they seal very well. Final Audio E’s are stickier but they didnt work for me as I was in between sizes and the sticky material gets slick and slides out if you suffer from condensation issues
yeah but those are the short ones, the ones with the grey stem are the ones I use
I see in my country i can only buy the earfit xelastec tws will they fit
I am copying list to the post with my impressions on the device on different thread in this forum.
TL;DR - plenty of power, clean sound, nice build quality, but terrible app, crappy usability for a BT dongle (size!), too expensive. Not recommended in short as compared to Qudelix 5k at least for my use case
Is there any reason why one can’t clip this to one’s shirt, if one has a case with a clip? I happen to like the clip the BTR5 comes with and have often used it.
BTR7 doesn’t come with a clip case, but if there is one somewhere it should be fine
Enjoy.
US $12.99 | FiiO SK-BTR7 Leatherette protector case for BTR7
https://a.aliexpress.com/_mNAF2f8
Ok, I pulled the trigger and an putting my BTR7 through its paces. Sounds magnificent with my Andromedas.
Does it sound better than the 5? Really hard to say. I think so. Not night and day., But better. I think it’s a touch more revealing, and the treble is a tad brighter.
It is quite a bit larger, which might be an issue for when I want to clip it onto my collar for calls. Otherwise, no.
I’m curious: what happens if I use the lineout function with my Asgard? Stay tuned.
when I compared 5 vs 7 I found the 7 to have a bit better separation and soundstage but the sound signature was the same
My new BTR7 battery last about 3 hrs on full charge. Using 4.4 cable with Mest2 or S12. Boost is off.
Is that normal?
What is your gain level set at? I’d say I get a similar battery life with high gain on, using the balanced output.
What I might be hearing is more the Andromeda treble living up to its reputation, if that makes sense. Sort of, it’s allowing the IEMs to stretch its wings. I should try with my Etys next.
this is super surprising to me. I get at least 6-7 hours with the Qudelix on high gain, balanced in performance mode and I usually keep high gain off to get an extra 1-2 hours
