Do these pair well with the BTR5? I was looking at the P1 as my next IEM, but I need something I can power from a btr5 or the likes of it, since itāll not really be used for at home.
Forget about the P1 + BTR5 lol.
The FH3 should be perfectly fine with the BTR5.
Last question if itās okay: Any reason to invest in a balanced cable for the FH3 or would the SE be plenty?
The BTR5 has 240 mw with the balanced output, while 70mw with the SE. Go for a balanced cable.
Thanks for all the info!
Iām very sensitive to vacuum, but I donāt feel anything.
Gotta shout out to @Rikudou_Goku for how knowledgeable and helpful he always is. Well done. Thank you for being such an awesome community member!
If you have an amp that has a balanced output, always go balanced.
Okay so I just got these and havenāt let them āburn inā (whether it be brain or physical burn in) enough to give my opinion, but I was just listening to this song and it gave me all sorts of feelings in inappropriate places on the FH3.
I guess itās the separation and very nice bass of the FH3, but I had a small eargasm which I wanted to share ;).
welcome to the club,
as always, try different eartips, source and cable,
then sit back and enjoy the music.
Wow no kidding, feels like the track was made for the FH3!
I just found an outlet deal on the BTR5 to accompany the FH3, now all I need is two balanced 2.5mm cables (1 for these and 1 for the T2ās to complement them).
Are these any good? Iāve seen the 16 core mentioned plenty, but these I can get (semi-)locally which would be preferable to ordering from China.
EDIT:
Another question, anything I need to look out for when getting a 2.5mm to 3.5mm adapter so I can also use them on my desktop gear?
I recommend that you get the faaeal litz copper, kbear rhyme or the Tri Through cable rather than the ones on amazon.
And just avoid 16 core cablesā¦they are much lower quality and I have doubts if they even soldered all the cores in that small connectorā¦
I cant think of anything to not do with a 2.5mm-> 3.5mm adapter. But do of course be aware that a 2.5mm plug is pretty fragile since it is pretty thin.
When it comes to recs on those adapters I would get this: https://www.aliexpress.com/item/1005002046158714.html
This one is the one I prefer but it is an adapter to 6.35mm
I have all his music. I use this to test soundstage. Great stuff.
None of those are found locally, so Iād have to wait a month and pay customs
. Only options I find locally are the FiiO lc-b which are twice as expensive.
There is also this one but it doesnāt have the hooks for the ears:
yeah, I always import them and pay some extra import fees. But I think they are worth it, it especially helps if you get more items at once.
for some reason, my fh3 sounded better on the stock cable than the tripowin cable i bought
Well, I dont rec the Tripowin cables lol.
what third party cable brands you rec? and ty
