No, have only heard the fa-10 and fa-12s so far
mannnn⦠i dont want to return my v280 but you know i have to when headphones play with correct channel balance on my tablet, so i may hop on and i may also be dissapointed, i dont see how it would not just be a straight downgrade but i havenāt read much, i just started reading. it would not be a problem waiting for a v280 replacement but i didnt find my ODAC and i dont want to sit with nothing for like a month or whatever, for now iāve reduced the gain on the right side in peterās EQ APO
Did you try contacting vio support?
The fa-10 would be an overall downgrade from a 280 unless you had something like an he6 possibly, but otherwise it would be a noticeable step down
Yeah that is irritating, your best bet for the time being would be to adjust balance in software
yap, they thought it was a lower volume thing while i was in the 6 and up towards 12 depending on gain setting which is what i told them, havenāt heard back yet, contacted the store i bought them from as well, havenāt heard back yet.
fun fact, 1db really does sound like double the volume which is what i have it decreased with, not sure on the details but it was something like, the loudness of the volume does not lineary increase with each db gain like you would expect with math, not sure how much there is to that but thats what a youtube video showed me and it is also what it sounds like to me. If you decrase one of your channels by 1 you may experience something different
yeah not gonna be an option then, thanks. may just have to use my onboard PC audio then lmao, that will be something else
I received the amp a long time ago, but I only got to listen to it recently. The Pro version sounds noticeably more detailed across the entire range. The high-frequency range is more accentuated and articulated. The low-frequency range has also become more concentrated and faster. But I would not say that the sound of the amplifier lost its fullness or became completely cold. I can say this is what I needed.
I started a thread specific to the Volot here: Flux Lab Acoustics Volot. Would be nice if we could get some discussion going about this amp. I have one on order and canāt wait.
what dacs are people using with the FA-10?
New limited edition FA-10 with entirely redone internals (honestly should have just called it the FA-100 then to avoid confusion but cāest la vie)
FA-10 Limited Class-A Headphone Amplifier (fluxlab-acoustics.com)
