What have you done lol, you have exposed him too early, now your wallet will suffer lol
You arenāt supposed to start him off with the Clears man, now (*a lot of) everything else will sound like crap to him.
Yeah, his brother has the BT Vmoda Masters. I think weāre going to give his brother the Magni 3 eventually.
He has some inexpensive kids headphones for his kids fire tablet, but every time Iām listening I get slapped on the arm with him saying headphones, headphones, headphonesā¦lol
I have to make sure I put them all back on the wall mounts otherwise heāll go sit at the desk and put on wherever pair
Adorable! ![]()
I have a picture somewhere of my son wearing some Q701ās thatās really cute. Little onesā with headphonesā¦
Youāve definitely set the bar high.
I think they make him feel powerful too probably! ![]()
At least heās being exposed to great stuff at an early age, regardless of price! ![]()
What exactly IS W shaped? Lacking in transition between important frequencies? Loud? Lol
It has a bit elevated bass, elevated midrange, and elevated treble. It isnāt neutral because some of the frequencies that are dipped down inbetween, typically pleasing signature thatās enjoyable
Where do we draw the distinction from where one of the three turns into the next? Are there frequencies in between, say, mid-range and treble that would be considered neither mid or treble? I think thatās what youāre saying. I just didnāt know that was a thing.
Also if anybody knows where to get the cheapest set of new clears please let me know! ![]()
So the elex actually measures somewhat flat and similar to the clear, but the presentation is different which gives it the more v shaped sound. Typically for a w shape the upper bass and lower treble will be a bit recessed where the midrange will see a nice hump if you wanted to recreate a graph based off of listening
That makes a lot of sense!
And really makes me think that I really would prefer the clear > Elex.
I would gladly trade 1% of the Elex mid-range presence for 1% wider soundstage, which is something that I think could easily be a perceived effect from flattening out such a W.
Here is what I will say. Grab an rnhp and a dac like the enog 2 pro and see what happens first before you jump on the clear. Itās also a good prerequisite for the clear lol
Problem is my Elex is long gone. I guess I canāt even say āmyā anymore ![]()
But I can say that the clear is one of the few headphones thatās been tested on my actual setup and I loved it.
Ah well that will be an issue lol
Itās been around 3 weeks since I received my Clear Pro and about two weeks since I started listening with the RNHP. (Already gave my thoughts on it over HERE) Figured it was time to give my thoughts on these as wellā¦
These are simply precise and oh so clean sounding, to use the namesake āClearā is not a overstatement, a quite fitting way to describe this sound. The naturalness and tonality are the best Iāve heard in a headphone and the soundstage while not super wide or deep, has this very unique spherical space where the music just sounds like it is playing a couple feet around your head 360 degrees. I donāt really have much bad to say about this pair of headphones.
To put it simply, I think these headphones might have ruined me haha. They just sound so much better than most of my other cans. I find myself not wanting to listen to some of my less capable pairs when I know I have the option to just listen to these. The pairing with the RNHP really does make the difference though, I never thought a amp could make such a noticeable change in enjoyment. I might have to seriously start looking at my collection and start culling some pairs that donāt get a lot of use.
Donāt get me wrong though, stuff like the 6xx and NDH20 (both on tubes) as well as my sendy aiva still very much have their place in my listening rotation, but others will definitely need to be looked at now.
Lol, well glad you are enjoying them ![]()
What about the other way around??
It depends on the amp you have. If you arenāt willing to jump to a higher tier of amp just stick with the elex, but if you are willing to upgrade the amps the clear makes sense
One is marketed towards professionalsā¦
Holy crap!!! The clear is significantly different from the Elex!!!
Iām so much more in the analytical! I canāt believe anyone would ever say they sound the same including myself. Also they really are SIGNIFICANTLY easier to power.
Before I only heard them in a noisy audio store.
These are less āfunā than the Elex for sure, but crazy clean. Iāve never heard any pair of headphones this clean. The name makes so much sense. Also, I canāt think of a logical reason for this but they are more comfortable than the Elex. Mainly they seem to fit without being too loose. Could be that they are brand new nothing more or less.
For once I agree with Zeos and disagree with Josh V.
Soundstage is more immersive on the Elex, and the sound is laid out right in front of you with these. I finally see where Z got his opinion of Elex vs clear but itās very obvious that this is a higher quality item than the Elex. Hearing things I havenāt heard before.
It makes sense that they came up with a āproā version. I canāt think of a more honest reference set for mixing.
But hell no to Zās comparison to beats saying that these are for bass heads. Elex has more bass.
This really is a flat FRā¦wow. I can feel myself wanting to EQ for personal taste.
Looking forward to trying Genres that I thought were lackluster with the Elex.
Thatās great ![]()
Correct me if Iām wrong but didnāt Z say the clear and elex are close and itās not worth with the clear (which is clearly incorrect lol)
The pads are different so perhaps thatās it
I use mine for mastering all the time, but do note the pro is just a different color and different accessories, same headphone
He said this because of a bad mismatch with his amp, they are pretty picky. He used the QES reference which has a very very high output impedance and significantly altered the frequency response of the clear.
I wonder if they preform better for you because of the easier to drive but more picky nature. Typically on lower end gear that has adequate power the clear and elex sound somewhat similar but with a different fr, they really come alive on a good amp, I wonder if you are just getting more power now or if the elex you had was flawed
