šŸ”· Focal Elegia
I know, right?! From a company that does this for a living!
I shall heed your advice, Sir. It will go in the trash tonight.
Or I will tie up the gate with it! :grin:
Or the wife :smiling_imp:
Cold solder joints can work in fascinating ways, yep.
Oh… Good call. Forget the gate! :laughing:
Ah that totally makes sense! I don’t think I’ve ever managed a cold solder joint, usually if I don’t solder correctly it just doesn’t make a connection.
I have the same short cable.
Especial cue as a Studio Headphone:
They got the version with the ā€œonly 50% shittyā€ cable lol.
Love Mr. And Mrs. Patreon
HA! Nice to see the Elegia’s in action. She wears them well, although I can’t believe she is using that janky ass cable! Catchy tune, btw. I like the bass line, and the sax player stands out for sure.
I just had another epic evening session with the Elegias last night. These are really sounding good with the BF2 > SA-1 combo. I can’t figure out if I like this pairing or using them straight out of the TA-20 best; they are both pretty darned good. I see hours and hours of listening ahead to make that determination!
I also got them from Amazon Germany and I’m glad other people have gotten the black cable…I was worried for a minute!
Original pads on my Elegia wear down after about 1 year and I decided to take a risk and get the Dekoni Elite Sheepskin (solid) for them. Couldn’t be happier, they got a small bass boost that add to the Focal Slam. They also upped the isolation a tiny bit more. The clamping force did get a little higher, but the overall improvement is totally worth it for me.
At $89 can seem steep, but if you liked the Elegias give these pads a try. Or maybe wait for a b-stock, got mine for almost half the price. I don’t know how but I’m in love all over again with these headphones.
Edit: grammar, sorry.
Finally placed my order. They have been on sale at Adorama for a few days at $379.00!!
Looking forward to these. :+1:
If you don’t have one already, get a dual 3.5mm cable to avoid focal shity cables. Also can recommend the Dekoni Sheepskin if you want a little more bass.
I was fortunate to have a Hart one ready to go from a different headphone; the one it comes with is so janky lol
I use the Hart cable system, but I might have to get a second 3.5mm cable as it stays pretty busy. :grin:
Haven’t thought about other pads yet, but I will keep your suggestion in mind.
If you own a pair of Elex, is it worth it to buy the Elegia? Looking to get a nice pair of closed back headphones.
I did because I like the Focal sound.
Put these on for a bit on Wednesday. Didn’t care for them much at all.
On Thursday they sounded better. Still kind of veiled though. Like there was a filter between the drivers and my ears.
Today they sounded much better. Is it burn in? I don’t believe in physical burn-in, but I am a big believer in brain burn-in. Especially since I was going from a very, IMO, technical, precise headphone in the LSA HP-2’s to the less precise Elegia’s.
But now I am Really into these. I will run them straight for another day or two and then start doing a comparison. I want to compare them to the Beyer T5’s and decide which is better. One will become my mobile solution.
I will test first in my system for a day or two and then a day or two off my LG V30 and my Sony DAP (NW-ZX300).
Everything that’s mechanical and subject to movement/flexing/etc. is going to change. Including your joints :slight_smile:
