Do you think it is as technical as others mention?
Give me a couple of days to listen to them and break them in a bit.
Iām always unsure if I understand what technical is in this context, my initial impression is there is a lot of detail, soundstage is very solid and quite wide.
Massdrop has the Elex pads up for sale (Shipping April 2020) these donāt drop very often and are a much better price than the Clear pads.
Yeah came here to mention the same thing. Wonāt ship for a while⦠but these pads usually cost $200 from Focalā¦
Itās a pretty good idea for elex owners to pick up imo
Just did. I wonāt need them for a long time, but future me just saved $140.
Any elex and m570 user who can share their comparison between the two.
Will Monolith 788 portable work with ps4?
Is it worth upgrading from the 6xx?
I think so imo, but you do loose the bit more relaxed sound. I think itās worth it
So would they kind of sit between the 6xx and 1990 in my setup?
I think they would in soundstage and relaxed-ness. I think they have more detail than both and the dynamic range is larger. I think itās a good addition imo
I have a couple of questions.
I know the elex is technically superior to the 58x, but will one enjoy and get as lost into the music with the elex more than with the 58x? I.e. Will I nod or toe tap more with the elex?
How does the elex with elear pads compare to the Clear? I heard that it improves them and makes them come very close to the clear. Is that true? Does anyone have any frequency graph comparisons?
Regarding the 1st question I would say yes but that really depends on the person lol.
For the pads, it does adjust the signature closer, but I donāt think it replicates the clear, as the clear is more than just frequency response. Also tbh most people seem to actually prefer the more fun signature of the elex.
i asked Drop to refund me 100$ for the sale and they did it. Iām sure you can too Polygon
Just read this whole thread but want to make sure that thereās not any new info out there.
Any pads out there that take the drivers a little bit farther away from the ears that donāt mess with the sound in a negative way? A little wider soundstage is okay.
Or any other mods to make these a little less likely to move around on the head?
Regarding the pads, the focal headphones are very dependent on pads and most pads will change the sound one way or another. I think dekoni makes some elex pads, but I personally donāt recommend them because of the sound changes, but some do like them
You might be able to do some things to the headband to prevent them moving, but I donāt know it people have done mods for that
I missed the boat on pads. My nonchalant, passive attitude cost me. I under estimated the demand/stock for these as they sold through.
Yes they were only up for about 12 hours, reading between the lines it looks like Focal dictated the limit.
Iām going to guess they donāt like cannibalizing the sale of Clear Pads even though they are supposed to be slightly different.
yeah, they are the same exact pads focal sells for $200⦠for the clears⦠so Iām not surprised they are so stingy.
