Hello all, I want to first warn you that I’m a newbie to the audio enthusiast hobby and so if there is one or more things in here that are incredibly ignorant I want to take the time to apologize in advance. Also, as someone who is new, your advice is invaluable to me and so thank you for your time and effort to help.
To start, I was looking for headphones that would be good for both music and gaming and, being new, used Zeos’s headphone guide as my source for headphones to consider (Z HP Guide) and there came upon the Fostex T50RP (AMZ Link). It checked off literally all of my boxes on what I was looking for in a headphones and at the right price point.
The real problem came about when learning about the headphone’s supposed powering issues after watching Zeos’s and Joshua Valour’s review (both are timestamped to when they broach the subject). Both state that the Fostex T50RP is a huge power hog and that they had very few amps on hand that they felt were up to the task of driving it.
I used this power calculator on digizoid with the 50 ohm and 92 dB/mW sensitivity listed on Fostex’s site and got the following chart of results:
From these results, it doesn’t seem like an amp would necessarily have to be that powerful to drive the headphones, unless they were trying to push it to the “Very Loud” and “Painful” loudness levels. Is there something here that I am missing? What makes this headphone so inefficient and power hungry? And most importantly, what is the true power requirement to make this headphone work to its best ability?
On a more practical note, I have ordered the FiiO K5 Pro DAC+Amp combo and according to FiiO’s parameters it is capable of outputting:
- Max current of 500 mA
- Max voltage of 19.68 Vp-p (~14 Vrms)
- Total output power of 1.5 W to a 32 Ω load
So, based on the power calculation, there seems to be plenty enough power voltage and current to drive this properly. However, if the power calculation was correct, then neither Zeos or Joshua should have had such a hard time powering it, correct?
If you made it this far, thanks for sticking through. Any insight or guidance to my questions is very much appreciated.
