Man Iāve been mulling over this all day, never tried a planar but Iām also thinking of the Clairvoyance. Reviews are all over the place
Ive tried the Ikko ARC neck IEM thing and that did OK.
530 grams for the dual magnet version
Å¢hank you. Ordered.
The GL2000 on drop shows a different grill. Does anyone know if thereās a sonic difference? Or perhaps Drop posted the wrong picture? I know thatās happened with other products.
I think itās Gold Planarās fault. They had been known to not update the model picture even though they had made changes on the headphone. For example is my GL1000 which had some differences with the model picture.
The different gril is the single sided. The double sided has the grill style yoy linked
Got it. Thanks.
Ordered, letās goooo
Would the Ifi Zen DAC enough to power these and be a good pairing?
Wow⦠that sound demo Zeos did for these was amazing! Normally I would write off the sound demo, but this one sold me on this headphone. Anyway long story short⦠ordered! Now the waiting beginsā¦
If you have these listen to Lil Darkie Swamp the sounds coming out of these on my IEMS are amazing so cant imagine the imaging on the GL2000s.
Ah fuck. Well I couldnāt really not buy them after a review like that. Totally not in my budget given that Iām waiting on some backorderd TH900s right now. Hoping theyāll both show up around the same time so I can make them fight it out, then return the loser.
@ZeosPantera hey bro how long are orders taking from Linsoul?
Would I be able to run this off my Magni Heresy if I pair the included cable with a 3.5mm male to 4.4mm female adapter? Something like this: https://www.amazon.com/Female-Balanced-Output-Adapter-Weaving/dp/B07DFH4JD1?th=1
Yes, you would.
I know I was gonna get verum 1 ml 2ās finally or T60 Argons⦠Now⦠Iām. Thinking I need gold Planarā¦
MAN I want these so BAAAAD. Problem is their just BARELY over my budget (400$), and as a high schooler with no allowance itās near impossible to push it. Ig I can dream
