HD660s vs Sendy Aiva?
Also this is my first pair of open back i’ve had and the only problem i have with open backs so far is that when there is a fan in the room the air sometimes makes an annoying sound/ring. And how would you recommend moving them around for lan parties etc? They seam very fragile. And is dust an issue with openbacks/electrostats?
So if you wanted more bass you can set up a systemwide eq if you would like
So I would treat them with a bit of extra care. While open backs in general are not that picky, electrostatics are and are and attract dust when they are on, so you do want to store them somewhere away from dust if possible. Regarding the noise from a fan, it’s possible that it’s because the diaphragm of the headphones is flexing because of the air pressure
I can double this idea. The E95X Really comes alive with EQ’ing. You can get LOTS more of everything.
