Hey so I’m looking to switch out my current desktop set up ( Edifier S350DB). I was originally looking at the Triangle Borea BR03 but I’m not sure what amp/receiver would be best for this or if I should be looking at other alternatives. I’m pretty new to the world of audio and would love to venture into budget friendly options for a speaker set up. Thanks in advance!
honestly for a desk it’s gonna be hard to beat those edifiers, they’re actually designed for that, bigger stuff gets boomy on a desk and still has less bass than those cause of the sub, I’d probably go with vanatoo t1 for that budget, or maybe replace them with the t0 and a sub.
welcome to HFG!
what makes you want to change your desktop speakers?
My mom wants them, so I’d figure I’d get something better for myself honestly
ah hah!
how much space do you have for these?
Vanatoo Transparent Zeroes are really nice. Active speakers with a small footprint.
I run mine with an SMSL SU-8 DAC feeding a Monoprice Liquid Spark amp feeding my Zeroes. Great sound, small footprint and a good amount of power.
I was originally running Topping D10 to Liquid Spark to Zeroes.
About 160 square feet for the room. My desk is pretty large so I have space for most hardware (I think?)
Would I need a amp/dac for them and If so any suggestions?
Oh dunno if it matters but I listen to pretty much every genre under the sun (rap, anime osts, punk, folk, edm, etc…) I have my own headphones I use for games and just want to use these headphones for music and occasional movies.
nope, they actually have an integrated usb dac, I run my t0 of a liquid spark just for the volume knob tho
Invest in a sub with hi-pass filter emotiva 8in $299. Or a cheap 10in sub with no filter. Basically invest in a subwoofer.
I say go team component setup. The sub provides grand scale and buying seperates increases the fun factor.
top link klipsch 10" for 140$, bottom link 12" for 150$. good sale deals on em.
bro3 back at 349$ if you plan on going that way
Damn, that price has me sold on the bro3. Any suggestions on what kind of amp I should get to power these?
There are a lot of great options under $600 that will serve you well. Studio monitors are another great way to go if you want simplicity. You don’t need a separate DAC if your motherboards DAC is sufficient, but I recommend running any Studio Monitor out of an audio interface for better balanced sound and less noise and they already have internal DAC’s included.
I was originally looking at studio monitors for the past month since I already have an audio interface (PreSonus Studio 24C) but I’ve been leaning heavy towards the Br03 for a minute (ended up buying them since $349 sale). Just need to do more research on the best way to power them and I think I’ll be ok? Dunno that my motherboard has a decent onboard DAC (MSI Z490 Unify ITX) but least it has optical lol
Why would you do that just for the volume knob? There is a knob on the right speaker and they come with a remote?
He probably just likes the knob feel.
budget for amp?
You wouldn’t need a separate DAC for studio monitors if you used your current audio interface. You may be able to use it as a DAC in your new system as well, but I’m not sure how you would hook it up to the amp you are looking for.
As for amp recommendations, i have had good experience with Emotiva amps, but it seems their cheaper amps are temporarily unavailable. I hear Crown amps are great if you want pure power.
