Preamp output: Plug this in to your powered monitors (or a power amp) using a 1/8” TRS to dual
RCA cable (for most products—others may need different cables, consult the manufacturer.)
You have this type of cable?
Just ordered one that my next step duel RCA to 3.5mm Australian terms lol
You seem to have a ground loop, you would want to isolate the speakers to a different plug away from the computer
tried different power point same issue
Tried plugging the fulla into a different USB port seemed to reduce it but not completely get rid of it
Hello a bit of topic, but if anybody knows, is there a difference between the Adam T5V and the Mackie MR624 ? Only considering the Mackie for the low volume quality. If anybody has both auditioned them let me know.
i have not heard either, but the mackies are known to be great at low volume play, but the adams will trounce them in any decent volume.
Tough call… but thank you. If anybody has another opinion I’m all ears.
This reviews says the mackie 524 are a tad better than the adam t5v. I can imagine the mr64 even better.
