đŸ”¶ Hifiman Edition XS
I think I will go for a Hart Audio HC-9 cable, over the NewFantasia/AE stuff. Not sure what material the Hart cables are made from, tho. (Answer= “oxygen free copper from Mogami”) Should I get a copper or silver cable for XS
Actually, THIS looks like The One! $163 for 4+4 strand hybrid, or $239 for 8 strand
 Will I hear a difference?
Huh could only explain that much difference with bottom of the barrel cables, if you have a multimeter a quick impedance measurement could give an explanation
I run a FiiO M11 <4.4 to 4.4> xDSD Gryphon Edition XS and I love everything about this setup!
Why the M11? Does the Gryphon DAC sound so bad? Or just because you have all the music on your DAP? But then you could use Bluetooth to the Gryphon or USB out from the M11.
Powerwise it is not a big step either (M11 550mw - Gryphon 1000mw)
Ifi Gryphon and the XS are a great pairing.
You just had to say that, didn’t you???
Lol just showing some nice synergy between amp and HP :stuck_out_tongue_winking_eye:
I should caveat that I still think the XS could use more power but the gryphon makes up for it with xbass.
Seems we had a similar idea. Came in today, decided to ditch my TV >qudelix 5k (dac) > sp400 > 15 feet extension cord to the couch setup and go back to a easy time where I just had a xCan and a hd700.
(4.4mm cable is on the way)
Oratory1990 did measure a couple pair of these a couple days back if anyone missed it. 87 preference rating and eq didn’t change much, ending at a 89.
One more new review.
That preference rating is kinda silly to me. I mean, I remember him putting the pc38x as like 102/100 after EQ and laughed my ass off. Those things absolutely do NOT take EQ well and I remember a corrected deva hitting 100/100 which is pretty ridiculous as well, IMO. The scoring seems almost arbitrary with some things hitting like 107-109/100 and I feel like actual technicalities don’t play into the scoring whatsoever, just how closely a simple 7-10 band EQ can get the FR to his target.
This idiot is back thinking the world needs to hear what he says about this headphone :laughing:
after reading all the reviews I thought of ordering a pair. I don’t know about their policies. This is the first time I am going to buy from an international store. which would be the best store to buy. and if I buy on the Black Friday sale do they provide a return policy? regarding shipping, I had no experience with USPS mostly I prefer Aliexpress. I heard USPS liteblue doesn’t guarantee if the product is lost or anything happens in case. So, I’m scared.
any suggestion or advice is helpful for Mr.
Thank you
These $20 stickon sheepskin earpads off AliExpress are just the best and probably the only upgrade I needed for my pair.
Just perfect! @Pokrog mounting rings is no more a concern. For no good reason, $40+, those ones. No need really.
Did someone paired the Edition XS with Topping DX5?
I would like to pull the trigger in this combo, but I don’t know if the DX5 is enough.
Thanks.
Guess You can only find out yourself. If you read along the thread you will see the opinions about required power differ a lot. Some are talking about speaker amps, some others say the normal 1W-3W range is enough and myself saying they run fine of a Qudelix 5k (210mW).
Why the DX5 ? It seems to be barely any better than the DX3 pro+ but double the price.
DX3 pro+ : 116 dB SINAD, 1.5W @ 32Ohm
DX5 : 122 dB SINAD, 1,7W @ 32Ohm (XLR headphone out is not balanced)
Only thing would be the XLR out on the back, don’t know if you need them for some powered speakers or so.
I didn’t think about it
 almost same power and efficiency. XLR is not balanced as you said (missleading).
No need for outputs speakers. And quite cheaper
 hmmmm. Thanks for opening my eyes! :sweat_smile:
Or to save yourself from FOMO you could use the dx5 money to get a power house like the topping A30pro with a DAC of your choice.
E30 if you need a remote.
Modi or atom dac to have something in your chain that is not developed and made in China.
Maybe a Zen DAC for the bass boost if you don’t EQ (Zen dac doesn’t measure as well tho (90db). If You care about measurements
