šŸ”¶ HiFiMan Sundara
You can check here:
Or try using this query in that thread:
https://forum.hifiguides.com/search?q=sundara%20topic%3A29781
Thank you!
Hi,
I have a hifiman sundara but.
The left driver stopped working literally overnight. ,
I tried to inverse the jack . So I plugged the (r) jack3.5 to the (l) driver and still nothing.
While on the right driver, the left jack worked.
So the problem isn’t the cable…
I don’t know if it s the connector or if it’s actually the magnets or something else…
Is there a way to test?
I don’t know what to do ,the guarantee expired
What can I do ?
So, my Sundara replacement unit just arrived. My question is if there’s a stealth magnetic revision for Sundara too or is it just a myth? Can’t find much info on the internet about it. I cannot open the box yet but if this stealth revision is real is there a practical way to verify it?
The only ā€œstealthā€ revision was called that because they secretly changed pads. Driver hasn’t changed ever.
Thanks for the response. It’s good to know. I’ve read on reddit a while ago that someone got the ā€œstealth MAGNETā€ revision of the Sundara and it sounded weird to me, cause I knew that only HE400SE has stealth magnets. I think he meant to say stealth revision or something.
I would open it up and check if it’s just a loose wire as there’s been quite a few cases of bad soldering jobs.
Hi guys, i have a newbie question:
Can the Tempotec E35 drive those?
I had not used the Sundaras for a while, so I took 'em out for a spin last night. But they sounded off, somehow. Just kind of hollow and flat. Definitely not what I remembered them to be. At first I thought it was because I have been listening to other cans and my ear was off. But it was more than that; these things were lacking fidelity. Something was wrong.
Right off the bat I decided to replace the balanced cable I had on there with the one I had on the new HP-2’s. And BOOM! - They completely woke up! In fact, they sounded better than I ever remember them sounding. I have never had a cable go ā€œdeadā€ on me before, but there it was. Problem solved. But now I am down a cable.
I don’t know why, but suddenly I thought ā€œWhat about the Stock Kennerton cable that the HP-2’s came with? I know it isn’t balanced but It’s a great cable and I bet it would sound great on the SP200.ā€ So I installed it on the Sundara. First off, this cable looks killer on these cans! Then I connected them to the TA-20/SP200 combo at the SP200’s 6.3mm SE jack. Holy Shit. They sound incredible on there! This Preamp/amp combination continues to surprise and impress. The Sundara loves it.
I never thought the Sundara would sound this good when running single ended. I was wrong. This particular pairing is fantastic. I think I am going to use the word… Synergy! :grinning_face_with_smiling_eyes: This grouping has it. Moral of the story? The Sundara can go single ended and perform very well. I’ll probably get another balanced cable in at some point, but I’m not in any rush.
80mw into 32 Ohms. Hmm… I’m not sure that will get the best out of them. As mentioned above, I am throwing a good amount of juice at them to get them humming. This is just my experience, however. That E35 looks pretty cool, though.
Due to Sundara’s weight I have to get a more lightweight daily headset. I will keep the Sundara for shorter auditions. I was thinking of Sennheiser HD600 (they’re about 30% lighter) but I heard bad things about their soundstage, is it really that bad compared to Hifiman headphones? I used to own a HD560s and I’ve had headaches from how congested and in my head everything sounded.
Is it possible to save up a little more cash and get the EDXS?
But it’s some 40g heavier than the Sundaras.
You might want to get your hands on a set to try it. I can tell you from personal experience it does not feel heavier…
just get some ksc75 if weight is that much of a problem
I already have a KHP30i and I’m happy with them for what they are but I wouldn’t listen to music more than 30 minutes on them cause I have much better IEMs for that, they’re great for gaming though.
So, I’m looking for a medium weight pair (150g - 300g) that is technically apt and doesn’t have a congested soundstage, even if it’s not quite as good as the Sundara. The Sennheiser HD 600 (270g) looks great but I’m afraid they might be similar to the HD 560S, which gave me headaches with how shouty and congested they sounded (imo) lol.
yeah the 560s are way wider than the 600, the 600 line is probably more like the kph30i stage wise, the 560s did give me headache but it was more about how clampy and bright they were tho.
Honestly I don’t think there’s something that compares to the sundara in stage and sound quality but weights less, you’d probably have to downgrade in something…
I’ve been lusting for the Sony Ma900 which are discontinued and impossible to get where I am, those maybe look like what you’re looking for, there’s the audio technica r70x which supposedly compares to the hd600 and are super light but idk how the soundstage is in those
I’ve decided to get the AKG K712 Pro, a very European choice, relatively cheap here as well ~ 250 usd. They’re said to sound great all across the frequency range and have huge soundstage with excellent imaging. Fingers crossed.
You’ve got a win on the soundstage front with those. The presentation is much different than HD6__ series, which as others wisely indicated is probably the tightest open-back soundstage you’ll find, more-so than the 560s. They’re great for some things, but actually freaks me out at times. An interesting ā€œotherā€ reco if someone liked Hifiman planar characteristics and wanted broad staging, lighter clamp and lighter weight - the Drop exclusive 5xx. I bought that on-release when I was EXACTLY looking for a diversion from high-anxiety HD6__ soundstage tightness, and it delivered. I do not think it is as technically capable as Sundara, however.
The K712 sounds boosted in the lows and upper mids, no doubt. I can’t really think of an over ear that sounds the same, even more so with that soundstage, so at least it’s unique in that regard.
