You should ask FatFreq about the filter, they started putting them on the V1s now so they might have a solution for you.
oh right on well luckily i have to wait a bit anyway so ill keep my eye out for it to see comparisons thank guys
Thatās actually what Iāve thought about just this morning right after my article I wrote. I was going to just try out some micropore tape but that was no good. Figured as such - thanks for the suggestion, brother - letās hope the shipping from Singapore isnāt 4 months for 2 filters ![]()
That will change the tuning, if you just need a protective filter. Get one like this.
https://www.aliexpress.com/item/1005004967649995.html
(essentially zero damping.)
I had a few but they were too small unfortunately- these are in my AE cart no doubt lol thanks for the suggestion!
Cables Shillers on HeadFi going strong.
I get spicy when I hear this load of crap.
āFeel the beatā , āWetā never heard terms like this used in a wire!
I like my bling cables and can honestly here a slight difference but honestly cables donāt make that much of a difference and most canāt tell stock one to a $2000 cable.
They go up to 5mm.
Yup - Iām going to measure the nozzle of the MMs when I get the chance. The problem with them is that there is no inner lip like other IEMs so thereās not much to hold onto for the filter. Iāll just have to attach it to the outer rim and hope it stays in place.
If the FF MM V2 will have a bass and trebble boost is great news , I would suck up that base and slap a filter nozel on so sweet.
I hope you hear back from them. I tried to use their chat feature last week to ask about the V2 and they never responded. No email either
I guess if a filter doesnt work, then u could try the low density foam like this.
Since the nozzle seems to be pretty wide, it should have minimal effect on the tuning, since the foam wont be compressed at least.
(and you could also just cut it in half if it does affect it slightly.)
I think @rattlingblanketwoman tried that without success
Yeah Iāve heard theyāre so swamped with orders, their response time is at a snails pace unfortunately. I mean, Iāll give it a shot regardless.
@Rikudou_Goku i appreciate that suggestion, brother - maybe Iāll give em both a shot, might as well have extra tuning foam and nozzle filters lying around. Theyāre so cheap itās not a risk whatsoever to try at the very least.
What is that Gray cable all the way to the left?! Itās gorgeous! Also - spending anything above $250 on a cable is absurd - even spending $250 is absurd but I do enjoy a nice looking cable.
To say it changes the sound completely is ridiculous ā¦.
Mostly used to describe a hose
if not then I predict a short ![]()
That is by far my most favorite cable copper/silver/gold mix bla bla bla but itās modular and so incredibly soft and flexable.
If I buy that one again I will ask for flat 2 pin.
C$ 90.04 5%OFF | HAKUGEI Joyful Voice Gold plated occ & litz silver plated occ & litz 6N occ 3.5 2.5 4.4 0.78 MMCX
https://a.aliexpress.com/_m0YdiUe
Ahhhhhhh yes - I had my eyes on that cable for a while. Waiting for it to go on sale tbh
Same cable but just OFCC , again you can ask for modular , earhooks if you wish and flat 2 pin are all options. In 4.4 it pretty cheap right now 1/2 everyone has it on.
C$ 37.49 40%OFF | HAKUGEI Lucky voice headset cable 2.5 3.5 4.4 0.78 mmcx
https://a.aliexpress.com/_mqAdoGm
Totally agree much softer than other fabric cables I have tried. Nice! congratulations.
Not to be cable shill but the Joyful Voice does sound a smidge softer on vocals to me.
