yep 10k is probably my max now…need to re-do a Youtube frequency check again ![]()
Wait for reviews on Simgot EA1000
Kinda affordable if you squint - Dunu Vulkan
If you’re a moneybags - Sennheiser IE600, 7th Acoustics Supernova
…or if you lie on your back and kick your feet in the air, then choose the natural upgrade of IE6oo → Prest LTD…
youtube compresses the sound and cuts the higher frequencies, use sites like these or high frequency sample tracks.
Wow. Just about heard 15k. I thought it’d be worse than that.
+1 to the IE600 rec. It’s definitely on the upgrade path from EA500. It adds a nice sub bass boost to that signature. Prestige LTD is also great although less neutral bright and more balanced
I always though it’s so set-dependant that this kind of test can’t really be relevant for anything, really.
That brings me to the question: with what set do the specialists measure your hearing capabilities? are they calibrated devices? Why aren’t these kind of thing chased by (at least some) members of the community?
Ok. Question for the group…
Knowing that I can only hear up to 15khz, is it still worth spending kilobucks for an iem or will I pretty much get the same/similar experience from something considerably cheaper?
I gave my Magma a little boost for treble extensions. Now the build-in ESTs shine as intended ![]()
Thanks @thoohil for the measurement!
Great work! But one concern. Electrostatic drivers (ESTs) in multidriver IEMs are intended to spice up the treble / air regions only as they are separated from the other driver types by a crossover network. Yet I haven’t seen a single driver EST in IEMs to work for all frequency ranges. So that’s why you can’t characterize this driver type for bass and mids apart from real electrostatics in headphones. ![]()
Right, AMT drivers is what I meant.
Next step would be to characterize the different Balanced Armatures by Sonion and Knowles as some users prefer certain models ![]()
I wish I was that moneybags, but nope unfortunately I am not. Though I will keep those in mind on what you have recommended and thanks.
Got a nice BA battle going on here, all of them are super nice.
Supernova 6BA - Butastur - 10BA - Neon Pro 10BA - Alita 12BA - Ljoma 5BA
Still no SR8 ![]()
Yeah, I might get one on loan onetime. I bet I would like it.
Still my preference will always be with a set with a DD for low end.
That said, my low-key point is there is no upgrade on EA500 below Vulkan. So save your money and don’t go chasing waterfalls
(10 of those characters)
IMO, the Vulkan is not the upgrade to the EA500. They are pretty damn different.
