tips make a huge difference in bass performance on the FH3 for me. partly due to tip bore size but more importantly the insertion depth caused by different tips
seems to be the FH3 is the first set I have that counterintuitively has better bass when it’s slightly more shallow in my ears. could be Fiio’s odd venting system getting blocked against the outer ear messing up the bass venting, not sure exactly.
but those are a couple things to experiment with and if I don’t pay attention to those two things I often get dissatisfying bass from the FH3
@Rikudou_Goku, what’s your opinion on Sony XBA-N3? I saw you ranked them very high but I’m interested in how much are they different from FH3?
I have a chance to get them for ~140€ (used) and am tempted to buy them. Or would you recommend anything else in this price range? Perhaps your newly acclaimed OH-10?
Having owned all 3 they are all close, but the cache of owning sony and a discontinued product at that is tempting for sure. I’d say all 3 handle bass pretty close with the fastest maybe being the fh3, but I’d be splitting hairs here lol. And treble is well extended on all of them edge to oh10. Mids I prefer the sony/fh3, where the upper mids are more intense and can be shouty on the oh10. But if you need the extra intensity I think the oh10 does a good job at keeping it clean and less fatiguing than others that attempt the same thing. Sorry for self inserting but damn if I dont like all 3 LOL
Received mine a week ago. Bought it after @Rikudou_Goku gave it strong and unambiguous recommendation for an iem suited for hiphop music (truly appreciated that you took the time to guide a newbie on this forum - thank you!).
I will get back with some impression - but for now I can say that bass is something special - damn (coming from BLON-03, hifiboy os v3, sony xb90ex, vsonic gr07 BE, audio technica im70)
Can’t wait to receive mine. Do you use stock cable or you have aftermarket?
Because of @Rikudou_Goku, I also bought 2 additional cables from his list.
Not sure how my wife react to this but if I have iems in ears, I can’t hear her, right?
I advise you to not change the cable after you connected it to the N3 (and the FH3 as well). Since the mmcx connectors arent meant to be switched around that much. Very likely to damage the N3 and since it is going to getting more and more rare, it would be a shame if it died.
I would use the balanced one on the N3. A factor for that decision is that if you decide to get another cable later, I would much rather change the cable on the FH3.
