One the one hand, not great! On the other…easy fix?
Oh yeah should just be able to put some zhanlida glue on it which I have plenty. Will glue it later and see how it goes. It has barely any traces of glue on the nozzle, can only tell there was some because it is a bit sticky.
This is something I heard happened with other users (2 afaik at least) so guess it was only a matter of time before it happened to me…just hope this isnt widespread…
This have happened on both pairs I have had😅
………lol:joy:
When did you get them? My unit is from around November last year.
The first was an early unit bought new by me, and the second was a trade I took, and probably early too.
Edit: Checked now, the trade was February 15. So probably bought new late las year.
hmm, all the reports I heard are from units that are pretty old then. I dunno if this was an issue with the early batches or if it is still an issue…
I knew this dude was going to kill it with the photos
this is just a taste. Looking forward to more impressions, brother!
Short answer yes, but it depends on how active you are listening and how much treble you can take, also volume plays a significant role here.
It can be so different from track to track and I did not spend enough time listening to techno yet. (last 1.5 hrs)
But I think I am with Dom here, techno needs to be blasted (reasonable), therefore i made minor EQ adjustments for that scenario
For me not every track needs that adjustment but for some it makes listening much easier.
If i want to make sure that i can have an easy listening throughout my very mixed electronic Playlist i would probably leave EQ on, there´s still plenty exciting treble energy left ![]()
This is one of my critial tracks for example
Bass is very satisfying and definitely not lacking, neither is it overpowering imho
i was playing with different eq settings for fun today and this particular one was very interesting and i had to share it here, its very simple (only 2 inputs) and turns ANY earphone into a boomy dark brain rumble machine( basically hip hop mode). the q values are very low so the boosts or reduction affects a big area and no need for more inputs. don’t expect resolution or clarity of this setting its a fun setting.
30 Hz Gain 3.0 dB Q 0.2
6000 Hz Gain -7.0 dB Q 0.2
Thankyou bro for taking the time to write this up, I think best bet is to wait for Deuce to show up to make a decision, I just see all the hype and get that fomo.
You are welcome!![]()
Estrella is a fantastic sounding and technically competent set.
It really can compete with higher priced stuff and does not need to shy away from a comparison against Monarch MKIII for example.
I can only speak from memory but @n00kie will be the next one after me to review Estrella and can chime in to make a direct comparison with Monarch III.
Separation is its strong suit and is on par if not better than my Kinda Lava…stage is also a little larger from first days impression, still need to A/B directly though.
Probably not a bad Idea to wait for Deuce reviews but you can’t really go wrong with Estrella from a technical and value point of view.
If you are someone that uses EQ (just in case) it’s an easy rec
I’ve been seeing this a lot from the EM6L, sound so smooth the nozzle falls right off
on another note, KE4 and Explorer to me are both the same flavors in a way from FR sniffin, so I’m excited to get both at some point and try em since I just donated my Orch Lite to my friend
please compare with B3 and hype2
i need this view
regards
I can’t ![]()
(bla bla bla 10 characters)
I’ve reviewed the Sound Rhyme SP01 the latest under $100 banger. I really love this single DD with its ibasso shell and quality driver. Peacock obscura reviews - #24 by Andy_Pickard
