Hi. I am new to the IEM world and i wanted a recommendation.
im willing to spend up to 1000 dollars
I’ve been researching and i was almost decided on the Campfire Andromeda, but now with the release of the Moondrop Blessing 2 i’m kind of tempted by the price (less than half of the Andromeda). From what i’ve heard, the Blessing 2 has a better tonality, better bass dynamics and similar detail in the midrange.
The Andromeda wins in soundstage, treble detail and maybe imaging.
I value soundstage and imaging a lot, also detail, clarity and separation, wich are things the Andromedas are very good at.
I would love to hear a comparison between the Andromeda and the Blessing 2, specially regarding soundstage. Is the Andromeda sounstage worth all that extra money? Is the Andromeda soundstage and imagind that impressive? Like, rivalling full sized headphones?
I have no experience with either IEMs but from what I’ve read the Andro is likely the higher quality performer out of the two. With that said though it’s hard to deny the value the Blessing 2 brings to the table, so really you have to ask yourself if the money for the Andro is worth it or not. I personally would maybe buy the cheaper Blessing 2 from someone like shenzhenaudio that has a excellent return policy and see how you like it and if you are still left wanting for more go for the andro.
but if money is really not a concerning factor just go for the campfire, by all accounts i’ve seen it is the higher tier IEM.
I don’t think many IEMs in this range can rival full size cans in staging, for that you would most likely have to step up a tier or two in price. But Im sure there are some decent options with good staging just not the absolute best. Andro I believe is known for having a spacious stage for IEMs at least.
i believe Shenzen ships from China, a better alternative would be Apos Audio which is located in CA and they also have a 30 day return policy.
I listen to all kinds of music. But mostly acoustical, and vocals. Jazz, classic rock, a bit of classical music, and only a tiny bit of electronic. But mostly “serious Audiophile music” haha.
I intend to use the IEMs mainly with an Ifi XDSD. But would be good to be able to power them through my phone
No, no IEM can rival an over ear tbh, in the same way an over ear can’t a good speaker system, but on the flip side phones and iem’s deliver a more intimate sound, which makes for good gaming with some HP’s and good detail retrieval and speed in iem’s bang for buck wise that is.
I run my Andro’s using an iFi Micro iDSD and love what they do, I think they partner well with the Burr Brown chipset, they’re detailed, articulate and truly sparkle on the genres you’ve listed above
Sorry but I can’t comment on the Blessings as i’ve not had a chance to listen to a set yet
Thank you for the answer. I’m pretty sure the Andromedas are going to be very very good for me, considering my preferences and gear.
I was just with that little doubt. After all 1000 dollars is a lot of money. That’s why I was thinking about the Blessing. But I think soundstage is very important for me, and it’s worth the extra money.
I heard the Andromedas have some of the best soundstages for IEMs. What was your reaction when you first listened to them? Would you say they are one of the best soundstaging IEMs? Noticeably bigger than it’s competitors?
I’m sorry if I’m bothering you, but I’m really looking forward to this IEM. Because I spend a lot of my time in transport (about 4h a day) and a very good IEM that lets me focus on my music is very important to spend my time well. Haha
Wireless IEM suggestions any one ?
To use with Phone .(i cant wear the iphone inside box earphones it hurts my ears as soon as i wear)
To listen to music at work .
IP rating would be nice as I work outside (not necessary)
I listen to all kind of music.
@Poi400i One other curve ball rec for those genres is the Tin P1 they work well iFi source gear, you have enough power on tap to drive them and x-Bass to give the bass a boost if you need it…the only down side for me is their nozzle is very shallow and you need to find a tip that seals well for you, once that’s sorted they’re banging $ +++
One other thing is. My ears are very very small. It’s weird actually. Hahaha.
I think the Andromeda will fit well, but the Blessing seems like it’s pretty big.
Also, I will have a chance to try the Andromedas before I buy in a store. I live in Brazil, and I will travel to NYey York City when this pandemic is over. So, I will buy them there. For the Blessing I would have to import from China.
And Brazil import fees are enormous, It would end up arround 550 dollars instead of 320. And the Andromedas I would pay the normal price in a store (arround 1100).
That’s the main thing with iem’s is a personal fit thing, try before you buy (Canjam/store?) or a good returns policy (iem’s?) No good having a $3k iem if you can’t get a good seal.
Personally I have no fit issues regarding the Andro’s and use spin fit CP 100’s, the set’s form factor isn’t large and anatomically they fit well and quickly. The only issue I had was with their original memory wire cable, eventually I removed the wire and hey presto no more problems lol.
