Not really imo, but the t3 is still good
I had the luck, perhaps filly, to try today the tfz no3 and god, as it sounds!
I think it gives more clarity and detail than the tin t3 but keeps the treble and has an impressive subwoofer.
I liked it very much, the best thing is that they cost 80 euros less than the ikko oh10 that would be my other option.
Have you got any thoughts on the OH1 v the KXXS?
TIA
How are these for long term listening? I’ve been considering these instead of my Meze 99’s. I like the Meze a lot but I’m looking for something better for office and traveling.
The sound is great for that, but comfort might be an issue due to the weight
That track is like a massage for your eardrums! Sounds amazing on oh10s!
Lol Yepp, its super easy to tell with it. Also the reverb low note in https://youtu.be/U0cDa4rewbc is a great iem bass test, like nothing reproduces it like the OH10. I think it is beacuse of the very deep sub bass as I’ve not gotten the same response even with eq.
I think I must have gotten used to them, the feel quite comfy and I can easily do couple of hours in them.
It really depends if you are sensitive to the weight and if they put pressure on your inner ear canals, it bothers me but it might not bother someone else. Glad you don’t have any problems ![]()
Hi|
Which one should i get?
-Blon 03 (€ 45) + 16 cable cores (€ 60), total € 105
-Ikko oh10 189 €
It would be to listen to movies, edm and some bso.
I ask this question because the blon is turning youtube upside down, many people say it is the best below € 200.
Personally I would take the oh10 unless you are budget restricted
Same. Owning both, the OH10 digs a little deeper, plays a little wider and fits more naturally in the ear IMO. You can’t go wrong with either the OH10 or the BL-03, though. Unless you’re looking for a purely neutral or bright sound, either one is a fantastic choice.
I’d also go with the Ikko OH10. I have many pairs of IEMs but always end up using the OH10s for the reasons Sonofholhorse mentions.
Yes. Ikko oh10 is very good.
Maybe one the best fun iems in 2019.
We are waiting the Tin t4.
Oooo that’s a big call lol…03’s, Tape, T800 and the S8F the list is getting longer
Would the OH10’s be much of an upgrade over the OH1’s?
I would say so, but its not a massive difference, but if you like the oh1 and want something more impressive the oh10 is pretty nice
I find myself craving more bass
They will deliver on that lol, with the right tips they are pretty great for that
