Ikko OH10 New Flagship
Good to know that..,by the way OH10 without titanium coating also looked good :winking_face_with_tongue:
Is that an OH10? Did you strip the coating?
Nope, it was a photo posted by Ikko before the launch of OH10. I wouldn’t dare to do that for a sub $200 iem :grinning_face_with_smiling_eyes:
So after cancelling the order from Penon I ordered from Amazon and they’ll be here by Thursday. See how they differ from the Tri i3.
Curious to hear your thoughts on this comparison. I’ve got my eyes on these two but I’m leaning towards the Ikko because of the established reputation of the sound.
Should be here by Thursday. The a couple days to try them out…
What are you guys using to drive your OH10s? I still don’t have a mobile dac / amp yet, so initially I would be using these directly off my Galaxy S9 on the go. If I’m at my desk I would be using my Liquid Spark.
I use a Fiio M9 Dap + Topping Nx3s portable amp for my i3. Blon bl03 Zsx and V90 no need for the amp.
Most stuffs drove them fine. BTR3, BTR5, Q1 MK2, ES100 balanced.
Got mine today, will compare with the Tri i3 in a few days…
See if you can help me here. I just received this Tripowin C8 balanced cable for my Oh10.
Red to the right, earhook up and back. But the blue dot in the connector points down. Shouldn’t it point upwards. Has me puzzled. :thinking:
That’s correct, my cable is like that as well
I have ALL my other cables blue pointing up. I guess as long as both have the same orientation I will be all right?
I’m pretty sure it’s just the tripowin cable, it wouldn’t make sense for it to be the other way because of the ear hook. I also used a c8 on my oh10s lol
As always thank you, you’re the best :sunglasses:
Amy iem better than ikko oh10 less than 200€?
“Better”?..Here are some good options but it will come down to what sound signature you prefer tbh…
I don’t know about “better,” but I did enjoy the Oriolus Finschi Hifi Edition over the OH10. The Oriolus had a nice airy, almost tube-like, presentation and a little more relaxed in the treble region. I don’t have any experience with the regular Finschi. If you’re lucky you might be able to find a used pair of Oriolus MK2’s, which would be a substantial upgrade over the Finschi and OH10.
Or maybe s/h OBravo Cupid’s?
Isn Audio H40 195$, Isn D10 for 175. Very popular now in Headfi. I have the Ikko OH10 and I’ve ordered the H40.
