This is my current setup, PC - SPDIF - X1S - Headphones. I also recently got the line outs from the X1S hooked up to my Mackie MR524.
Im fairly new to the game, and Im not sure about how I feel about the HD6XX running direct from the headphone amp of the X1S, as I cant stand to listen to it for more than an hour as I feel my ears are fatiguing, they’re not painfull really, but there I think Im pushing the amp section to loud for me to be able to hear enough bass to complete the whole sound stage. But I’ve also tested out a friend’s Chord Mojo, using the same tracks, the HD6xx sounded magical to my ears.
Now using the MR524’s, I can get the exact sound that I want, even when gaming, and my headphones are now seldom used. I still want to use them equally, but I think because I find my setup too bright, that I subconsciously lean towards the Mackies more?
I’m still looking for that “bloom” that I felt from the Mojo, and my questions for you guys are as follows:
Is the X1S DAC section bright to begin with, or is it just the amp section.
Would getting a tube amp or any warmer amp solve my problem. If so, what would you suggest.
Finally, has anyone else experienced that “bloom” characteristic that I got from the Mojo, and would I be able to replicate that sound? Not keen on the Mojo because I want a desktop setup without the battery degradation factor.
Cheers!
P.S.
I also have SHP9500 and M50x for headphones. Sorry for the long post, its my first time here.
I think a tube amp would be something you would enjoy imo. The x1s might be a bit bright amp wise because the 6xx is kinda picky. You could get a warmer sounding amp too, but o think a tube is what you might be looking for
Bottlehead amps are good as well depending on budget. You can find great condition used ones for a good price if you are patient and look. Also look for used eddie current’s. used market is generally the best value market for midfi equipment.
I don’t think you would want to drive the argon’s on a tube, as they might sound a bit strange and not be powered properly. Most tube amps I have tried a pair on didn’t sound as good as a powerful solid state
planars tend to not like tube amps, but they can be driven by them. hybrids can be decent. I love my t60 argons on my lyr. But i also have the tungston tube wich is a very neutral tube. your aune x1s would most likely sound better with the argons than the senn’s
Looks like my like strategy would be to fix the brightness issue for the 6xx first with a Tube amp, then get the Argons, then an nicer solid state amp.
I would recommend the Asgard 3 over the emotiva because I think it’s a higher quality output that sufficiently drives the argon’s. I think the emotiva isn’t as clean in comparison
Also the basx a100 can’t drive my he6 to good quality levels lol. Not can it drive the raals either
