How much are you able to get it down to? I haven’t really looked into it too much but after the discounts I see it at low 60s
That’s the way to do it, brother. I’m looking at a few Hakugei cables my self. ![]()
If you want to splurge on a cable, I would go with CEMA stuff. (assuming you are thinking over the 70 usd range.)
I used to be in the camp that would justify paying multi hundreds for cables, but I’m glad I never did. I’m more so looking at these guys here;
https://a.aliexpress.com/_ms30gxI
https://a.aliexpress.com/_mq2guLW
https://a.aliexpress.com/_mLvMQRW
https://a.aliexpress.com/_mNbP5he
But they’re not even on sale so I’m not sweating anything tbh - I do have some CEMA cables in my cart though ![]()
Lmao one of the links I just mentioned to @Rikudou_Goku ![]()
nr 2 doesnt look that special considering that price and im pretty sure xinhs has something like that at a much cheaper price.
The other cables there look pretty big and is likely heavy which I do not like.
If you want something unique:
https://www.aliexpress.com/item/1000007909452.html
Or the cleanest looking silver cable
https://www.aliexpress.com/item/1005001901153004.html
Definitely going to check there stuff out.
Makes sense - I really enjoy my thicker cables for my desktop IEMs that don’t leave the house. I have the GreyRhino from NiceHCK to give you an example of how thick I like my cables ![]()
I have found that hardware can make or break weight more than the actual cable unless you are doing a 2 core. I got this chunky cable but went with heat shrink instead of a metal splitter and it’s surprisingly one of my lightesr cables
Beast set ![]()
The Meteor and Monarch are fine too I guess
With all the discounts, like $44
Damn, that is really low - so, are you gonna get a pair?
I’m trying very hard to convince myself not to. But I’m wavering lol
Lmao dude, it’s $44, live a little ![]()
Are you gonna buy it???
If I hadn’t just made that big purchase recently, I could justify it to my wife… right now, if I wanna keep my head, I better hold my wallet ![]()
SpaceCloud. There’s an ultra and a 2023 revision, I believe
Thanks, that feels like a great cable.
