Have you ever been scrolling through aliexpress, and you come across these lowkey brands, and thought, hmm, are these all doodoo or are they actually decent? Well today, I’ll be comparing some not so well-know IEMs to some popular brands to see how they stack up.
CADENZA 4
Starting with the new Cadenza 4 and the MYER CKLVX, (or the PULA PA02, they’re the same thing) these are going for a similar sound, both leaning towards a balanced sound signature, and both have a twist in the treble air region. The Cadenza 4 sounds very clean, balanced, and has that extra airiness towards the end notes of vocals and cymbals, very splashy and extended. Female vocals and woodwinds sound very good on the Cad 4, extended, open, detailed, very light and sweet sounding is how I would describe it.
Now, Vocals don’t feel thin, but they’re not very powerful or have enough note-weight when it comes to make vocals. The Cad 4 is very good for instrumentals like acoustic or classical, female vocals, or slow-tracks without much electronic elements - indie and ballads sound beautiful on these, but as all-rounders they lack the low-end and fullness. It just needs more bass to be an all-rounder as the low-end isn’t that impactful; the bass is well-controlled and separated but it feels light and in the background, which works for the style of sound they’re going for, but I wouldn’t recommend it for hiphop, kpop, rock, or anything that needs some low-end.
And as for the 13K peak on the Cadenza 4, it doesn’t sound as much as the graph suggests - you can still hear the boost, but it’s not shrill or shouty at mid volume. Supereviews’ unit also literally graphs like Harman 2019, so it could also just be unit variance or a potential measurement thing, but either way, if you want a reference-audiophile sound close to Harman 2019, then that would be the Cad 4.
CADENZA 4 vs MYER CKLVX
The CKLVX on the other hand also goes for a balanced sound, but it has more low-end, vocals and instruments feel fuller, and the treble gives the overall tuning an airy and dreamy layer to them. The Cad 4’s got more of a sizzle type of air to the sound, whereas the CKLVX is more smooth airy, if that makes sense. The vocal gain on the CKLVX is tamer than the Cadenza 4 and has less uppermids extension, it doesn’t feel as extended, whereas the Cadenza 4 is following Harman 2019, but with a boost in the air region.
Neither of these 2 are all-rounders persay, the Cadenza 4 sounds more resolving and detailed and better at mid-volume, but the CKLVX scales better and sounds fuller while still being airy, just not as clean and sweet as the Cad 4. Both of these don’t do too well with energetic tracks because of the treble, but for slower songs and genres they’re both great, female vocals and acoustics goes to Cad 4, whereas I’d take the CKLXV for slow-rock and alternative.
MYER SLIIVO SL41
But there is another MYER IEM that is an all-rounder, the SLIIVO SL41. It’s basically the Cadenza 4 but with more low-end and less treble. I like it more as an all-rounder because it’s fuller in the notes while still having enough extension in the uppermids and treble, it’s not as airy as both the CKLVX or the Cad 4, but it works better for more genres at the cost of not having that special sauce. Now, one potential issue with the SL41 is its vocals, the 500hz bump plus the decreased uppermids makes the SL41 more husky, less open and extended versus the Cad 4 or the Nova, not as clean and sweet with certain details missing because of the dips from 3-8K.
But I said potential because some people will prefer this sound as it’s fuller and less fatiguing in longer listening sessions, but for the harman lovers the Nova would be better, it’s better extended, less peaks, or if you had enough of the regular harman and want something different but still harman, then try the Cad 4, it’s cleaner, has more air, and sounds very sweet on slower tracks, kinda reminds me of the OG Oracles.
HISENIOR MEGA5P ULTRA
Next we have the EJ07M vs HISENIOR’S MEGA5P ULTRA, which is a 1+4. Basically, the M5P ULTRA is a mini EJ07M with more forward vocals and slightly lighter vocals due to less lower-mids. In-terms of volume the sub-bass and treble is pretty close on both, but the 07M edges the M5P Ultra out when it comes to the texture and detail, which checks out because it costs 2x more. Out of all the IEMs so far (CAD 4 & Myer stuff) the M5P Ultra would be the best all-rounder and more similar with the Chopin and Nova with the differences being in the vocals being more forward on the M5P Ultra and less uppermids.
Because the low-end is pretty clean on the M5P Ultra the vocals don’t feel as nasally even with the 1.5K bump - I wouldn’t say it’s ideal, it still feels a bit too forward and I’d personally would like less 1.5K, but you get used to it. Treble extension is solid, again no special sauce or super airy or anything, but overall the M5P ULTRA is good, it’s good… I would still take the Nova though.
The Nova just works better as an all-rounder because of the better extension and more opened vocals, I think Nova’s uppermids are fine since it’s not too much because both are mid-volume sets so it’s not like you’re blasting neither of these, plus the Nova is also cheaper with the same config. But if you find the uppermids too much on the harman iems still, then M5P Ultra is good alternative, just don’t buy it at retail.
HISENIOR T4 vs ARIA 2
Next, we got the HIESENIOR T4 vs the Aria 2, and TLDR, it’s a better Aria 2 with more tuning options. If you want more scaling boom, if you want mid-volume, boom. The T4 goes from balanced-warm to warm depending on the config, and overall, versus the Aria 2 it’s got better separation, sharper transients and resolution, but, for $199? Idk. Ok, so here’s the small issue with Hisenior IEMs, their tuning is good for the most part, but there’s just so much competition like the Nova, LM, Cincotres, all competing for the same sound signature but cheaper or better. I think the T4 and M5P Ultra can work as alternatives to those, but they should be priced more competitively around $100 to $150… aside from that, solid IEMs.
ALPHA & DELTA TWS (actual subwoofer bass looking at you SINGOLO
Then lastly we got the Airpods Pros vs the ALPHA & DELTA TWS IEMS, And it’s very simple, if you want bass, the Alpha & Delta wins hands down no competition, best sub-bass I’ve heard on any TWS so far, the closest would be the Samsung Galaxy Buds+, but the Alpha & Deltas are more tactile imo and just more of it in general (these guys know what they’re doing). I’ve been using them in the gym for the past 2 weeks, and I hear a big detail and clarity difference compared to my 1st and 2nd gen Airpod Pros.
The KS100 comes in two configurations, one is a single DD, one is 1DD + 1BA, both sound the same with a slight difference in the air on the hybrid (more). They both follow a diffuse field type of sound but more energetic because A&D boosted the sub-bass and uppermids, which sounds great for the gym when you’re trying to hit a PR. Now, the uppermids can be shouty at times and it’s definitely not as smooth as the Galaxy buds +, but throw on some mesh filters and you’re good to go, or EQ down the 4K by 3.5dbs.
Because in-terms of sub-bass in an TWS, these are the best under $100 or probably even more; the bass texture is really good for a TWS, and for more than half the price at $90 versus the AirPods Pros and Galaxy stuff, these are no brainers - this is what the Singolo should’ve been… You’re telling me A&D made a subwoofer in a TWS with no “revolutionary” bs tech, but Crin and Kiwiears couldn’t do the same thing wired with a “revolutionary tech”? That’s crazy, this is what a subwoofer should sound like in an IEM.
Now, you do miss out on some convenience features like active noise cancelling and transparency mode, and the controls aren’t the best, it’s tap to play/pause, and sometimes it would pause when I try to adjust it, a bit annoying, but battery life is solid, design looks slick, the case is sturdy made out of metal, and if you’re looking for the best TWS bass under $100, these are it, great for the gym, and if you got EQ, no brainer.
Anyways, hope this was helpful, thanks for reading
