Klipsch owners thread
So that’s the hard part lol, I would want to lean towards a soekris which actually might end up being fine for the parasound as well, but I would also give a nod to a holo cyan as that’s going to be a bit warmer pairing there but not overly so (but realistically the soekris isn’t going to be an issue since it’s being run through a tube pre for the speakers)
Which soekris do you mean?
2541 or 1541 preferably, but a 1421 would work (but you might need a switcher)
Both the soekris and holo are a bit out of my budget though. Can you recommend something in the $5-800 range?
Not really tbh, not much in that range that’s worthwhile imo (for a higher end dac), at that point just stick with the bifrost as it will still give you a fairly satisfactory experience
What if I use the rebel amp as a pre amp then I could probably get the soekris 2541. Would that chain work well with the parasound?
That would work pretty nicely actually imo
So, I was considering the RP-600M, but Z would have us believe they can’t hold a candle to the Swans M300 MK II…
What gives?
And how come I cannot find a thread full of M300 MK II owners raving about them?
Klipsch is more readily available you can get em at costco food warehouse.
Because everyone doesn’t rush out to buy everything he peddles. Those who do also might not agree with his sentiment.
