I would say so, but they donât have a more meaty sound then the t5p. They are fairly full compared to other estats, and right now the price is great, so I would say to give them a try for sure
That is my fear. I respect the clarity of the T5p.2âs, especially after I havenât used them in a while. But I donât love them like my Gradoâs or even my Meze 99âs.
I goose the bass on my Gradoâs and Beyerâs using my Schiit Loki which really adds to my enjoyment of them. I am guessing Koss would need the same.
Shane D
Yeah, the koss have pretty nice extension, but you may want to boost the bass a bit if you like that. They just donât have the physical impact if some other headphones, but that being said, I donât think they are bass light and I do listen to some bass heavy music on it and still enjoy it
With my preferences for music and gear, do you think Iâd enjoy them? And I donât listen loud. I find the T5p.2âs a little âsterileâ, if thatâs the right word. Would these be in the same range?
The quality problems concern me and seem to be ongoing. Sending it back forth from Canada will not be cheap. And my landed cost with the sale price is about $650.00. I can get used Elexâs here for about $700.00, which I am also very curious about.
Shane D
Hmmm. I would actually like the elex better because you can put them on a warmer amp and get better warmth, so actually I would suggest the elex if itâs that price
And I currently have five amps sitting around.![]()
Although I am trying to move the FiiO A5.
I just wish I could try out the Koss. Hate to spend that kind of money and go âmehâ.
The Elex sounds like it might be a good companion to my Gradoâs. I like having a choice of 'phones and amps to keep things fresh.
Shane D
I would also say the elex is actually more detailed as well. I just think itâs a sound you might appreciate more
Thanks for your input. I will keep thinking about it.
Shane D
I meant to reply earlier, but these pads are great and make a big difference in comfort while retaining the sound. I always use Dekoni iEM tips, but these are the first pads Iâve bought and I will keep you in mind for all my future needs. Keep up the great work!
I made pitches to three guys on Canuck Audio Mart for Elexâs and Cascades with no luck. Might just have to try Electrostats.![]()
Shane D
None of them will give you a good price? Thatâs surprising
Well I hope you enjoy the estats then ![]()
Everybody has their own way of doing things. I am curious about the estats and I will just try not to think about the loss if I donât like them.![]()
Shane D
Sweet! Glad you like them.
Canadians arenât big into negotiatingâŠnot like you are in the US.
Weâll soon find out. My car was in the shop today for servicing. I told myself that if there were no big surprises, I would make a decision.
Car bill was âonlyâ $536.00.![]()
Ordered E95X Koss set today.
Shane D
Nice, hope you enjoy it ![]()
You and me both!![]()
Shane D
I run into this problem so much.
Well I didnât know about this until now lol
Lol yeah. There are a lot of quirks about canadians that arenât really well known outside the national image. Especially when it comes to business.
