the beige PP is on it’s way from Japan…
KSC75 with Yaxi are my favorite
Any changes in sound with the yaxi pads on the KSC75?
OK so I am intrigued enough to buy the KPH30’s. But, can’t get them easily in the UK - what are my options?
You can get the KPH30iw on Amazon. They’re the same, just white. Otherwise, just import them, it’ll cost you about £10 in fees if you get them delivered by regular mail.
disclaimer: I could not get enough pressure with the standard pads - the fit was to loose
now it´s fine
If the gigantic staging got improved…
it was not needed, at all though love it!
“Money for nothing” sounds huge …
“cigarettes after sex” sounds like… chilled and intimate
“the one that got away” by Alice Kristiansen is still sibilant - it´s the recording … all good
“Someday we´ll Know” by the New Radicals is not peaky…
“Radium” by Edit Select … the deep and hard Beat does not bloat in the airy evolving background
what can I say … love the 75s
the low end is now more prominent - mainly cause of the better “seal”
not sure about the mids
the upper end got tamed down a smidge
Thank you! Seems to be available to import from Austria for not awful money.
That sounds like something I really want to try now! I always wanted a little extra bass with these.
Pics look sick! I got the same color way Yaxis I bought directly from e-earphone in Tokyo during my tour there, unfortunately I didn’t get those freebies, bummer! Also no Rhythm Beige available perhaps for all retail stores? Rockin’ the same KSC75 set and dark grey KPH30i instead, hoping to swap my Red+Blue Yaxi on them next.
BTW Something I’ve been looking for is pairing my KSC75 and KPH30i with a budget dac/amp combo. Any recommendations? Do you use one with yours?
I use Fio BTR3, Earstudio ES100 and ifi xDSD
stationary the RME ADI 2 DAC and THX AAA 789
Maybe you can look for the Fiio K5 pro for budget, it’s very good
I have as backup the Fiio Q1 II- you can get them used for 60-80
I am with you
I plugged my kph30i into my xd05+ yesterday and it made me question everything lol its surprisingly good… xd05+ is overkill though lol
The koss scale pretty well lol
I felt pretty silly doing it but do not regret it and will do it again lol
I’m just going to say I use my koss on some pretty high end stuff lol, sounds great ![]()
This comes to mind ![]()
The green light makes them look like alien or outer space headphones. ![]()
it is a fantastic photo lol I’ll get to try the 75’s soon ![]()
which makes me think even the ifi zen dac would be slightly overkill too as well, should I jump down to dac-x6 or k3? I’m using laptop on board currently.
I only really have experience with the xd05+ but my question would be are you using other headphones as well with the amp?
I think Koss is the most power-hungry I have hence why I’m curious for an entry-level dac/amp. Rest are Pro 82, Blon B8, and KZ iem. I also have a 2.1 logitech speaker set that I rarely use, now they’re glorified headphone extender through the remote lol.
