Donāt pull that shit with me. Thatās MY schtick!
The dangling carrot has been hung!
I didnāt realize peer pressure had trademarksā¦
LoL. I just meant that Iāve been using the palpatine ādo itā every time anyone expresses the slightlest interest in the Hemps for the past couple of months. I think this is the first time the turns have tabled.
Donāt be afraid to show us your wood
Those turned out very nice. They look great!
How do they sound?
Theyāre MKay.
What cable are you using with these TR-610?
Hi @arrakian - Welcome to the HFG Forum!
That cable in the picture is a New Fantasia cable that I ordered off of Amazon as a temporary cable so that I could run on a balanced amp while I was waiting for a custom one to be built/shipped for the TH-610
What wood number do you recommend for a Chord Hugo2? Thank you for your detailed insight.
What cable did you end up getting?
For the Lawtons I went with an LQI cables, Voda series. It was inexpensive and I wanted to try someplace different. Voda Series UP-OCC Copper Headphone Cable ā LQi Cables
Arctic makes some nice cables up too that sound nice without breaking the bank. Some others that are good as well are Oidio, and Forza.
If you want to go deluxe there is always Double Helix or Plussound - just depends on where your budget fits best.
Hello,
I have had good results with the Viablue epc 2 cable.
If you have the confidence to build the cable yourself, then it is worth it.
Thanks for info I just bought a nice cable from them. I was thinking Lawton but didnāt want to go that high and then Parriapt has that stupid splitter and last Hart is too thin. I have hart for my hd6xx and itās sounds as good as more expensive cables but no girth. So try LQI brand.
Placed my order for Lawton Purplehearts! 3 weeks out
Glad theyāre bringing back the PH. I thought that was going to be discontinued.
Yeah, I read that here. Figured it wouldnāt hurt to ask. Luck out, really.
He told me he wasnāt going to make anymore purple heart or bloodwood because the color wasnāt guaranteed to come out well even after a lot of work has already been put in. I guess enough people wanted it that he felt is was worth it.
So two questions. Do you have any pictures of the cups you ordered and are there any more?
