Oh yeah baby. I’ll blast some this weekend @ my parents ![]()
Congratulations. Try not to spend all your time outside doing lawncare like my house has done to me.
That’s what I’m afraid of, had many houses over the years where that’s all I did sans any iems, don’t know what I was thinking. Need room for a hot tub, and half hour mowin tops
Resolution hand reveal… hype.
Trully nsfw asmr.
You can tell he was nervous. First upload, normal stuff.
I just figured it was the age that was making his hands all shaky…
Sorry, too well set up.
Only 2 days away from retirement as well.
To be fair I think that clip is from lethal weapon 1 and the x days away from retirement is from 3 or so.
Lol… SENFER DT6 PRO is a total Nightmare. huge nozzles
Oh wow that’s way easier. Final E tips have always been a hassle to put on IEMs but they make the bass sound sooo good in a speaker-like boomy-but-not-too-boomy way
Hey can I check with you guys if I were to use M size tip on one side and S size tip on the other side, will it cause imbalance?
I realised that cp100 M size is more comfortable with better seal on one ear but it causes my other ear to get a little sore after longer duration. I don’t have any S size with me right now, so I don’t know if it’ll have a good seal on my “bigger” ear. I have a good deal to get 6 pairs at a discounted rate, so I’m not sure if I should get S or M size tips
You should be fine. Lots of people need different sizes. I did at start, but it seems my ears “normalized” to handle the same size on both.
“Normalised” to use the bigger or smaller tips? Haha
Not really sure. At first I tried everything, but I knew nothing. I only cared about max seal but not insertion depth
Also my ears feel different around the day. Happened to me before using L at night and then I wake up and only M fits
But I kinda figured it out by now.
Yea I just started noticing the differences when I vary the insertion depth and play around with the tips. Perhaps I should get a mixture of S and M
Is using a smaller set of tips but deeper insertion better? Or bigger tips with better seal but shallower insertion better in your opinion?
Difference recipes for different cakes. Everyone ears are different and every IEM as different insertion.
I usually prefer “deep” fiting, but not too deep like Etymotic lol. Like you said, I usually prefer smaller tips and deeper insertion with good seal. But that can only be done with some shells. Some shells can’t go deep enough, and for that you need longer tips with bigger size or more shallow.
I’m still messing around with stuff. I know my preferences and my prefered tips, now it’s about perfecting it
You would get more of an imbalance if one ear sealed and the other did not. Also the actual bore of the tip is the same on a small as it is on a large so it shouldn’t really effect it. Using different tips with different bore widths might cause issues though.
Thanks everyone! I’ll get a mixture of the 2 sizes then!
Well my Oracle has a fairly good chance of arriving today, but after watching an unboxing and double checking on Linsoul’s website, I am super glad I went ahead and bought a bunch of tips(sedna crystal, final e, radius deepmount) while a family member is visiting Japan, so I can get them from amazon jp without the crazy shipping, since the Oracle only comes with one set of silicone and a full set of foams(the only detail I completely overlooked). Thankfully I got some decent spare tips laying around in case the stock one doesn’t fit me
