Totally for the hybrid silicone.
Aint interested in anything related to foams.
Maybe Iāll hit up Sony USA and see what I can squeeze from them.
This all reminds me Iāve got quite a spending spree to do when I return to Japan⦠
What would be the closest equivalent in size and feel to Final Audio E type Medium tips?
The OG Z1R silicone tips?..Iām a large in Eās and a Large in the Z1R tips..
Feel? there the softest tips you can buyā¦in softness Z1R silicone tips>EP-EX11>Eās ![]()
Give me a minute and Iāll try and find a medium E to measureā¦
Edited hereās a medium Z1R tip which I think is the same size as a medium E tip?..
The prices are for 1 piece, so youāll need to order 2.
A straight up piece by piece distributor.
Ok, thank you!
Putting a type E on a 7mm nozzle, would that affect the fit in my ears at all?
I just tried the CP100+ and they are great on BL05s and FA E2000. They do increase the bass and the treble which works wonders for the E2000. They are super comfortable for me.
They donāt fit on large nozzle so Iāll try the CP155 next.
What kind of tips is recommended for large and long nozzles?
Iām having a hard time with my TP. So far the reversed Starling after i trimmed the stem are the best and i just ordered Sedna short and CP360.
Chopped foams.
Haha I triedā¦but itās uncomfortable after about 30 minutes.
Foams should be confortable but sound worse (comply). On big boys i usually go down a size in any tip.
On my Land I used sedna earfit (regular). Theres also the light and short version. They are good tips for bad fits.
On my Variations I do spinfit cp145/155 (more pointy end)
Radius deep mount has also a different touch areas so it might work.
Dose the JVC EP-FX10 Spiral Dots++ come bundel with any iem? Or u just have to always buy them extra?
Iāve been trying new tips but having shelled out for Spinfits, they just donāt work.
I seem to have a real problem with silicon tips. Just canāt get a seal.
Only tips that work for me are foams or Symbio.
However Iām going to try moulding my own custom tips as this should give the best fit.
Thatās what I figured I just ordered Sedna short in MS.
They should be here today
I honestly use some cheap-ass TWS tips. Might be worth snagging some from AliExpress for a few bucks. Just look for super short stems. Iāve heard Spiral Dots are rather short, but the overseas markup hurts my soul.
CP360 are good, but for some IEMS they seem to shift too muchāunlike CP100 and other normal Spinfits. For IEMs with long nozzles like 03s, you can push CP100s up the stem.
Good info, thanks!
Today I should receive Sedna short and CP100+ in Medium since Large was too big.
I was planning on getting CP360 as well but they were out of stock on Amazon.
Any general recommendations for tripple flanged tips?
