That’s a good point, i will try the acoustune ae07 but I’m worried they are not grippy enough
I agree. I like this kind of fit actually. I have BL-05s and Tape Pro that fit the same, but less floaty.
They are good but because they are soft they are floating more than others. I guess what I’m looking for is grippy like CP100+ but stiff like Final E.
I think those Acoustune tips are Kbear 07s, or whatever source they are. They aren’t very grippy, but not smooth either. Something like Kbear 08s, or the AET08 are rather grippy, but not the sticky-grippy like Spinfits, but more rough-grippy. I use them on my TWS because of that.
Foams can change sound a lot, but it’s different with many folks due to foam sealing differently in different ears. I can never get them to work because they simply kill bass and thus just push up the highs and mids to become too sharp. Maybe your ears are good with foams. Dekoni has a good variety of them.
Can you try to reverse some of your tips? Many tips have a matte finish, but if you reverse them their stickier side is exposed. E.g. Reversed KZ Starlines are stickier (and makes them longer for deeper insertion).
Ha you read my mind! I tried the reversed Starline but the stem is not rigid enough.
I’m actually trying to reverse a pair of unbranded silicone tips that i bought a while back. Let’s see…
I just wish there was a multiple size package… 🤦
So I have reversed some generic Medium tips that I got a while back from the Earphones Plus store on Amazon.com/us.
They were a bit more difficult to reverse that the Starline from KZ.
They are the best tips so far for the Oxygen. Super happy right now!!
It seems that they will size small and one might have to buy a size larger…
He’s is a cool tip for tips (
) i found on the ie900 topic to help IEMs with shallow insertion.
Ahhhh the old Blon 03 trick ![]()
i just got the spinfip cp500 in L because i prettymuch always use the big tips that come with headphones. but with these i cant get a good fit. just before it is about to seal it feels like the tip gets a creas i gues kinda like in the picture. maybe the M ones would have been better
M CP500s have a steep slope to the tip so they say 12mm, but I find they fit like 11mm in a bad way for me. I think CP500 are weird tips, polarizing in fit for many for sure, so don’t feel bad you’re having issues with them.
Have you tried CP100s? Maybe CP145s?
no these are the first tips i got because the big tips that came with the KZ ZS10 pro felt like they stab my ear in the wrong angel and the shape of these looked good (a S/M/L set would have been nice). but i think i got used to the stock ones.
i’ll probably get foam tips next but dont know if i should try a more expensive one like comply or dekoni or just some random one of amazon thet look good
CP100 are pretty good. But they are so soft that they tend to lose seal if you put them in too far.
To avoid this you could try Final Audio E tips or Azla Sedna.
Foam tips will change the sound pretty significantly, it will tame the treble and bloat the bass.
yeah the spinfits probably are too soft for me.
taming the trable is what i’m looking for becouse when i turn them up they get unpleasant before i reach the volume i want. but on low-medium volume they sound good.
but i don’t want to restock foam tips all the time.
I’ve just got a set of Spinfit CP155 and really like the cone shape and comfort but the bore size of 5mm is tad too big.
Does anyone know of any other tips with a similar extended shape but with a smaller bore size.¿
CP145? It’s basicly the same if I recall correctly
