Lets talk about your tips! ;)
Have you tried them?
No just looking at the way it looks.
Thanks but was looking for experience. I may use them on TWS but curious how they fits ear holes.
Just a warning thats all. Looks similar to the tips/nozzle on the samsung galaxy buds pro and those tips dont work well with regular iems and regular tips dont work well on that nozzle.
Anyone got any thoughts or opinions on Shanling SE100 tips? they look pretty funky :beers:
I think Niclas @Pseudonym got them and might be able to give a quick impression :slight_smile:
yes sir! They are similar to pentaconn corier and BGVP copper. But they have a lower tier of silicone but that is not necessarily a bad thing depending on use case. but if the metal structure does anything I’ve not come to any conclusion of value on :slight_smile:
Still on the hunt for new tips and seeing as I have Corier’s I Just ordered these out of curiosity…
Have you tried these totally-not corier copies?
https://www.aliexpress.com/item/1005009419826714.html
Picked these up yesterday, Baroque Stage…
I have. They run a bit small, size up. The surface is a bit rougher texture vs. the other Tanszu but seal is still very good. I start to ‘feel’ them after a couple hours though. Highs are crystal clear as I find they are with any of the metal insert-style tips.
OK Baroque stage are :boxing_glove: with Pentaconn Corier brass as my all time fav tips depending on sets and both fit :ok_hand:
To describe what each does/offers to my library and source playback…The Stage offers what i’d describe as a "solid state” replay…open, fast, dynamic, with great “stage” and detail. Where as the Corier brass offer a more tubie, warmer and thicker replay but they’re no slouch when it comes to detail, just doesn’t shove it in ya face/ears, they’re just more chilled :+1:
For me it´s either AZLA Crystal or Vivids nowadays…both of them are very versatile and balanced imho.
Crystal seem a little airier which i think comes down to a shallower insertion depth i have with them.
Vivids are a little sturdier and seal a little better for me.
I tried Prism Wide bore lately but they were a little too flimsy and did not seal very good…therefore the sound was very airy which was also kinda nice but those are not really for me…too much hustle and readjusting for getting a good seal
What is the emoji ‘red with white base’ supposed to represent?
I am going with “Boxing glove”
Boxing ie trading blows with each other
It must be adding harmoic distortions that are good like tubes, ie even or odd order resonance. Pretty sick really. Glad you mentioned this as it will go on my list to checkcout sometime
I know it’s probably a bit geeky and very pretentious but I prefer the Corier Bass over their Ali version :nerd_face::sleeping::smile:
If ever Corier Brass and Baroque stage have a love child then we have an endgame tip :smile:
“Thanks! I have ordered them and will be giving them a go. There are not enough decent wide bore ones on the market IMO. I use the TRI Clarions but they don’t always fit properly due to the shape of the flange unfortunately.”
@publicpersonae25
Continuing the tips discussion here :slight_smile:
Try BGVP W01 aswell, its another great wide bore tip, pretty short and stubby though. Also its very cheap and worth adding to a tip collection.
