I just have the equalizer to work with, so no to the Q values. nymz was able to help me with getting my Kinda Lava EQād to a Mahina type level, and I have a picture maybe this will help?
I see. Without Q values, unfortunately to my knowledge thereās no true way of getting the absolute correct EQ. Iāll be happy to help you for sure get those values, though. Youāre trying to EQ the Z12 to Mele or Kai, correct?
Iām just hoping to get close and then go from there, I suppose my main mission is to bump up the midbass a good bit properly so I can take a bit of the edge off the Z12 and get a better sense of atmosphere/immersiveness from the midbass at the same time unless Iām wrong so I thought any of those three were a good place to start. Kai isnāt up on squiglink yet though just a heads up. So short answer is yes lol
Okay, so - according to the graphs, on paper, the Mele for example, actually has about the same if not a little less mid bass as the Z12, with the Z12 having a few dBs more Sub bass:
(graph credit: @hawaiibadboy)
The difference being, the Z12 has quite a lot more Upper mids and treble, which is probably causing a psychoacoustic artifact of the Z12 sounding like it has less mid bass. I would actually leave the bass region alone if I were you and work around the 6k-8k region, bringing those sliders down;
And see where that takes you. Iāve attached the EQ values if you want to try to change the entire FR up to 15k. As you can see, at 7600 hZ, thereās a whopping 11+ dB difference ā¦
Try tweaking the 8k slider down around 5dB and see where that takes you and go from there. Luckily, planar drivers take well to EQ. One tip, if you end up increasing any part of the EQ, make sure you bring down the Pre-amp portion to match the increase to reduce distortion.
Best of luck, brother and happy listening ![]()
@RockinDave did you ever get that working, brother?
Hey man! ![]()
Yeah I gave it a shot just with the -5db since that seemed to be my biggest deal with the sound signature and it did make a good difference!
Just wish I could find myself loving the planar timbre on the Z12 and not be feeling like Iām missing the feel of a good ole DD ![]()
How about you when it comes to planars, feel the same way I do?
Iām happy to hear that dude! Iām glad the 5dB tweak made a positive difference. For me, I do not perceive Planar timbre as much as I do BA timbre, so itās actually no issue for me. I thoroughly enjoy the Timeless and a sizable amount of people claim the dreaded Planar Timbre on those, I just donāt hear it. But hey, If itās not for you then itās not for you - just be grateful itās coming from experience on a sub $200 set and not a Kilobuck set or something crazy like that.
- Hi, whatcha doin?
- Just trying my new 3,5mm to 6,35mm 20ohm impedance adapter.
- What?
- I mean, just listening to music.
I have never heard the term āswancoreā before. Genre names are really starting to crack me up.
Either way, HTS are pretty good. I have them on a playlist with Pierce the Veil, Sleeping with Sirens, Atreyu, Falling in Reverse, Bring me the Horizonā¦you get the picture. And youāre right, the S12s are perfect for fast and technical genres and they also do the clean male vocals of this style very well, IMO. I have my S12s modded, but even before I did they mods they I dug 'em for this kinda music.
The genre is a derivative of Mathcore. Which both have been around a long time now.
Itās not a ānewā genre, but it sounds brutal and very technical on the S12. From a technical point of view, the S12 does better than most hybrids
I still maintain that the S12 is the best planar out there right now, barring some very expensive ones over $1000!
What other planars have you listened to below 1k? I am asking for a friend who is also a metalhead and looks for something fast and techncal
I have listened to some in my friends: 7Hz Timeless, 7Hz x Crinacle, DUNU, PD1 (I have it, but it is a hybrid), Tin HiFi P1. Of the more expensive ones, only the Simphonio P10 (Iāve only tried it for 15-20 minutes).
I can say that S12 kills them all for metal and is close to P10. I havenāt listened to others now. Maybe the CA Supermoon will be better or much better, but itās $1500.
But tell your friend about the planar timbre - he might not like it, although on S12 it is not bad. I still technically prefer DD for metal.
anyone here have one? please post your impressionsā¦
My Glamdring has been out on tour too long for immediate impressions, but they are wide, balanced and the bass hits HARD. They are nothing like a stock S12 from my experience, almost like a final evolution of what an S12 could be if you wanted it less V-shaped and more immersive. For the money, I canāt think of a planar that I like more (although I do need to A/B with my P1 Max once they return to me, but they are also different tunings). I believe @cal_lando should have my pair when he gets his Fat Earth in, which is another Michael Bruce mod, so he can do comparisons between the two.
Iāll def do a comparison review on the glam/fat Earth once I get a hold of them. I should be able to get a fat Earth impression out next week but probably wonāt have the glams in hand until closer to the end of the month
I saw a video of short is where he talked about an iem that used the same driver than OG dark magician. Is the fatEarth the result of a modding of said iem?
I believe the S12 is also the starting IEM for Fat Earth; The Dark Magician driver was in the XSL X-One, a single DD. Iām not entirely sure what happened with that project.
