I live in a very humid country.
I NEED to use closed backs because small house, play in the night, etc.
Leather pads and stuff really really make my ear very uncomfortable.
My budget is 500usd, but I am down to hear every single suggestion.
I know velour closed backs don’t really exist, so I am down to mod with velour replacements, but I don’t know many headphones that still sound good after replacing.
I listen to pop songs.
I’ve tried Sony MDR7506 with DT250 velour pads. Pads were abit too shallow. Sounded abit too flat to me, I prefer something more “fun”.
I’ve also tried DT177X GO. Loved the sound, my favourite. But looking for cheaper options.
I would love to own HD820s, I’ve tried them out before but they are too expensive. These would be my ideal headphones.
I also would like to try NDH20. Looks good, but looking for cheaper options.
I mean, the 177x go and an amp like the liquid spark does fit your budget… but you don’t want to spend that much
The 770 250 ohm paired with a mangi heresy (if you want something more neutral and cleaner) or liquid spark (warmer thicker a bit smoother amp) would be my pick imo (and a dac like a topping d10 or smsl m100)
I would personally avoid the 32 ohm, it’s very unrefined and not that detailed, the 250 is the cream of the crop. You could get a portable dac amp if needed. That being said the 177x is somewhat fine without an amp (although they do benefit from one)
The 250 ohm preforms well with a high quality dac amp, it does affect performance to an extent. If you wanted something portable, an ifi idsd nano or xduoo xd05 would be my picks. I mentioned desktop solutions above
Well since we’re at the topic, I’ll like to hear your thoughts on these too.
They are the Monolith Hi-Res dac and Audioquest Dragonfly red usb dac. They’re super portable and I was thinking of getting something like this. If i get the DT770s, would it be usable with these?
I’ve… never actually thought about that! I just reversed my online nick that I always used and removed a letter from it, didn’t really wanna use the same name in every place. Online footprints can be scary. That’s a cool anagram though.
