That doesn’t sound like a bad deal…I’ll consider it
the other dac’s you mentioned…what are the differences?
I’d still get a D10 if you like the form factor. The D10 is also a newer model than the D30.
Yeah with what’s currently out there the d10 is my top and m100 is 2nd best for sub 100
How about just above 100? Or it doesn’t matter til much higher price points?
Well, I think you would start to consider stuff like the smsl su8 or topping d50s, and it just goes up from there. For your case I think it’s pretty overkill though unless you wanted the extra features
I can vouch for the D50 since I’ve been using it for half a year already, but it’s quite a jump in price.
It also depends on if you are willing to buy used or not. I recently got a Geshelli Labs Enog2 Pro for $75.00.
Yeah I’m not ready to more than double my price point…
That’s a pretty great deal lol
Dacs are a crazy price jump for each performance tier you take lol
Yeah, it really was. And so far, I prefer this DAC over the D50 (sound wise). Form factor wise, the D50 was a sexy looking beast.
You prefer the d10? So why sell?
Not the D10, the Geshelli Labs Enog2 Pro.
Oh got it. So just selling the d10 to move up in features?
Well there is an increase in sound quality too (I may have forgot to say that lol), it just gets smaller amounts of increase as you go up
you get more features the higher the price go as well as better base component and chips. cost wise the SMSL M100 has more features then the D10 at $10 lower price. But the D10 by technicality has a better sound score 104 vs 107 IIRC not enough to matter wither way.
I end up preferring the sound of the d10, but the m100 is also a fine choice
I haven’t heard the M100, but it uses the AKM4452 DAC chip, which has been around a while and is tried and true. I also like the unique form factor of the M100.
Yeah, I’m selling a couple of things so that I can eventually buy another set of ZMF headphones. I currently own the Atticus but want to buy an Auteur to compliment it.
I think the d10 is a bit higher resolving tbh, and a more cleanly signature that I think is better for the price, but honestly they are so close
