Luxury Precision P6/P6 Pro R2R DAP
Also checking it does seem that the 3.5mm works as a line out mode btw. Although I can’t tell for sure if I’m actually using line mode with the 3.5mm, but it seems to function fine and doesn’t sound like double amping to my ears (I can pretty easily tell the difference between headphone mode and line mode for the 4.4)
I have no idea, you do have a preamp mode so perhaps??? But that sounds a bit risky to me
Ground Shield
This works from Single-Ended into Balanced. The other way round, you need a “level converter” (or DI-Box in reverse).
Also for reference I use a cable like this to go from the dual 3 pin to rca typically to convert bal to se for dacs into single ended amps
https://www.bhphotovideo.com/c/product/1564405-REG/mogami_goldxlrmrca03_gold_3_pin_xlr_male.html
Yes, which is exactly why I though bal signal → se line was a no-go. You certainly can’t return the negative signal over a shared bal negative terminal without shorting afterall.
When you say se into balanced, you mean a se output over a balanced cable, right? Cause if so, thats the only of the options I thoyhht was ok to do. I had been reading basicaky everywhere that any other conversion was just a no-go
Hmm. No talk of pinout. Unless it uses a return line over the shield pin idk how it would work. Are 3-pin RCAs maybe wired typicalt with 3rd pin as a propper Ground to be used bal or se as opposed to just a shield pin?
Either way, just got home and got the p6p outputting into the micro BL over se LO and it seems to be doing quite well
I may need to up my inerconect game though :joy:
That is a question I can’t answer, but most cables similar to this one I have tried have worked without issue or problems
Don’t see how you can do that when you already have the totl
Nice
Balanced → Single Ended has the bigger problem of signal level being way to high (more than double of what the single-ended input expects).
Single Ended → Balanced is fine though!
Yes.
Single ended into Balanced is fine, for device interconnets and head-amp to headphone.
It’s “safe” to go balanced to SE with either a pentagon connection or 3 pin XLR, because they have a ground, and you can just drop -ve in most cases. You do need to check the cables are designed to do that though.
It is not safe to do it from a 4 pin XLR connector, because there is no ground, and wiring ground on the SE connector to -VE on the XLR will short the amp.
Ok. This is exactly what I though. Ima have to reread this thread cause I thought yall were saying bal line out → se input was fine
What i had always read was dual XLR and 4.4 made it “possible” not “safe”. Where as 2.5 and 4-pin XLR make it just not even possible
I think I like the micro BL more as an amp than I do as a portable…
EDIT: Vol control with the P6P is way better than vol control with the Micro BL
As you know, every system is about balance. I feel genuinely bad for this interconnect taht I am treating it with such utter disrespect
A few things to note as I use the device more.
  1. Hot damn does this thing look chintzy in the case. Like really cheap. The case being made of pleather doesn’t help that either. If someone handed it to me in case finger prints all over the screen I would legit guess under $500. Is real leather really such a big ask when we are legit using wood on the back? Its not even a veneer. And even if you have a moral issue with real leather, there are way nicer vegan case materials…
  2. The battery life in LO (as expected) is astonishingly good. I got about 20 hours of playback before I charged (and it hadn’t even died yet) with 1/3rd of that being on BT. My amp (micro BL) died 2 times and was nearly dead the 3rd time by the time I plugged the P6P in.
  3. The volume control on LO is quite finite and quite nice to use. I set a general level where the pot sounds good on the micro BL and then controlled volume with the P6P. Was quite a nice way to go about things tbh.
  4. The BT on LDAC is very very good. With the exception of certain super congested songs I’m not sure I would be able to pick out local or BT. That said, any signal at all and the device stops playing local music, so you kind of have to pick which one you want to be in. No playing voice messages over BT and expecting music to start again when it stops (that would be amazing though)
  5. It takes 4x longer to hold the power button to turn the device on than it does to boot (not an exaggeration, its 6s hold and under 1.5s boot)
  6. If you turn on the device and just press the play button on the side nothing happens. Not a big deal, but would be nice if it would play with the click of that button since it already remembers where you are.
The case is just terrible where I just use it without lol, I’ll take the risk if I don’t have to deal with the case
Good to know, I’ve only tested battery life driving iems so far and I’ve gotten 14 ish hours with medium efficiency iems. Also surprising that it lasted that long including bluetooth usage as that’s typically a battery sap in LDAC
And then like 30 min to warm up fully lol
I have plenty to complain about, but in the end, the sound makes it all worth it.
Brave brave man. I dont even run my phone without a case and its like 1/8th yhe price. Think ima look into just making one myself. The pattern seems fine at least, so I may just copy it and use propper materials. Need to probabaly get a different hyde though. Maybe see if I can get a couple pieces of Shell Cordovan. This player definitely deserves it.
With mest + iematch (this is working great btw. Not sure i even hear any sq loss, but uts tough to volume match back and forth to know for sure) on mixed local and LDAC, i get a comfortable 8 hours with 1/4 battery left before I charge. Do not though, yoy can abuse the fuck out of this battery. Got a hifiman 4.4 from a buddy until mine arrives in a few more days. Ldac + arya (actualy run surprisingly well btw. Obviously not enough amp, but realy admirable given the rated power output) and I was under 1/4 battery in under 4 hours
I haven’t been paying much attention to warm up tbh. Maybe I need to try some critical listening first thing tomorrow morning and see whats missing. Not entierly guessing my ears are that good tbh, but seems like a fun try either way.
I seriously seriously want to see impressions of the LP6 Ti vs P6P. It would seem the LP6 Ti may actuaky be better given LPs comments about it, but I can’t find fucking any English impressions on it
Ah yeah I have a case on my phone as well which also is like worth nothing in comparison to the dap lol
OOOO if you do that would be pretty cool
Perfect, for some iem’s I barely noticed it as well so that’s good
Gotcha, yeah the arya is pretty demanding, but with some of the more efficient headphones it really drives them well to where I might not want a portable amp with it
Been talking to someone who has both at this point (not the ti though), he personally feels like for iems the Pro is on par or slightly better than the LP6 and as a line out dac about equally good, but the LP6 has an upper hand for full size headphones due to it’s amp section. Would really like to try a LP6 myself lol. The Ti is on another level though to both (apparently from what I’ve heard)
That would look very sick and classy
Hahaha.
I’ll try and get patterns drawn up in the next couple weeks. If the cheap material one comes out alright, I’ll post here. Wonder if people would actualy be interested in a nicer one tbh.
Soeaking of, do you have any idea what the difference is between it and the earbudy? I can find no talk about how they actualy work and ifis offical doc on them explains nothing about the internals
Hahahaha. Yah. I wasn’t even expecting them to run properly tbf. I’ve been quite happy with the usage for my mests. 2 days of standard listening is quite acceptable since not even my watch lasts a full day in this digital world :joy:
Thats why I realy want to get hands on it. Its not a viable option for me due to how often I use BT unfortunately. Dispite that, hot damn am I mega tempted to pick one up (for 0 apparent reason)…
Hopefully its a fairly easy pattern. I believe it should be, but I don’t have a sewing machine with a reach over big enough to make it, so I will have to hand stitch which may change things. Guess we will just have to see. Sounds like a good excuse to get the lazer cutter I’ve been wanting though…
Then you can take some shoe wax and shine the crap out of it.
Earbuddy has a different impedance mix (2.5 ohm output and I want to say 15 ohms on the amp side), provides less attenuation, and is made with lower quality parts. Also can’t be balanced
You have to find one first lol
Guk. No ty. I’m a natural patina guy. Especialy on some good conagc or natural shell. Maybe even #8 if I can find a supplier (but shits be hard to come by recently and absurdly expensive)
Ok, so it is basicaly just a down market version of the same device? I had heard it said it both was and wasn’t and am just kinda confused since ifi won’t clarify
I’ve found one where a guy will ship from ausyieland in a chat im in. Not a bad price too. Shipping import and everything us still below retail and jt looks brand new. But I just sit there and go “BX2+, diana V2, 909, and 800S or LP6 TI”
Its keeping me from jumping, but holy hell am I not happy I’m still tempted…
