šŸ”¶ Mangird TEA (6 BA/1DD)
that’s good to know, I guess the two options right now would be the TEAs vs the a7s, if anybody has recommendations around the $300-400 range feel free to shoot
Add the Sony XBA-N3, Tanchjim Oxygen and perhaps the Fiio FD5.
(FIY the summer sale is coming up on aliexpress next week during the 16th-20th)
If you have the Legacy 4, I don’t think the Tea will be that worthwhile of an upgrade, unless you want to collect it or simply hear what it can offer. For a more significant ā€œupgradeā€, I’d suggest moving to the Thieaudio tribrids or maybe the Dunu 112 EST.
The Tea will have better imaging, stage and sub bass vs the L4 though.
I have to agree with this assesment that a tribrid would probably a more significant upgrade and/or better investment at this point.
Mine will be arriving in the next week or so. I’m hoping they will be my cup of tea…
Will be interesting to compare to my blon bl-03 and BGVP DM6. They’ll also be my first set of iem’s with a 4.4 balanced.
:slight_smile:
Just ordered these, 1st set of proper gear.
Simple question, are these any good using the Apple Dongle?
I plan on getting a dac/amp for home use, but want to keep things simple out and about.
Short answer: yes. More than enough!
Just tested this to answer you: 4.4balanced cable into 3.5se adaptor into apple dongle into Xiaomi mi10 playing tidal and at max volume is too loud.
I also have a fiio btr5 that can serve as on the go as well. On my m3x, i listen to my teas around 28/100 with balanced output.
Hope this helps!
Just got mine today. They’re amazing so far! Does anyone know how I can get more of the foam tips included in the package? The small ones are great.
Congratulations. I’ve asked Linsoul about buying the silicones and there was zero reply. I suggest checking out Comply and Dekoni if you haven’t already. You might like them even more.
Yes…
I do prefer these though…
Just ordered two packs of Comply Tx-500 for my Mangird`s. :stuck_out_tongue:
hello dunu est112 is a good upgrade from mangird tea?
That is debatable. Both are very good IEMs, but I don’t know if I’d say the EST112 is outright better. It will depend on your preferences.
Better cable on the EST112, absolutely, better IEM?
I like the EST 112 quite a bit, but yeah, as far as I can tell, the Mangird Tea is a pretty different signature, so it depends! Just for fun, I took a look at the frequency response graphs, screenshot below. (I also threw in the Clairvoyance as a tribrid that lines up a bit more closely to the Tea.)
I fixed it for ya.
:musical_note: All about that bass, 'bout that bass :musical_note:
This! Probably my next upgrade. Also keeping an eye on oracle, isn est50 and variations
This is a proper Mangird Tea upgrade…
That needs a nsfw tag :joy:
Made me do it…
