I would believe that the shell-chamber is indeed a different printed target.
One does not change size+curvature to adapt to community request and tell (me/us) its randomly hand made.
The chamber the speakers sit, has to follow depth targets as that influences’ air pressure targets (as also the airduct)
But it is a bit bizarre that they are supposed to sound the same. Can not verify sadly. Can not measure them.
The faceplate protective layer is thicker and irregular, which makes them standout outside of the ear.
This causes pressure on the bottom part, stretches the ear downwards and shrinks it a bit.
Soo the 200µm slightly bigger shell that should be barely an issue, becomes an issue.
The rermain part that bothers, outside of one being deeper it than the other ~ is the shell curvature
Its too sharp and reminds me of the Tangzu Xuan Nv ~ which was going for the same sharp shape.
It may work out if the shell is not as wide, but its too sharp even if rounded.
They went back on the 3rd day but gladly amazon and other e-tailer have no issue with a return.
Common selling practices for buying products online.
The right shell actually does fit fine
~ aka what everyone hopefully got here, but the left is soo different in everything.
If it was mirrored and both were bad, at least it was sellable them. But this, what is this failure
I believe it should be in the realm of possibility, but that’s another ~60$ for products.
Clear (medical grade) resin, 2000+ grit sanding paper & reading a bit there are some 12-15K grit glas? hand-files for resin work.
Issue being exaugurated due to stretching by no size control when swapping batches,
and generally big coating targets.
Else idea of sharper spike can work, if you don’t mess up everything else too.
Sanding the top (inside) layer will be an issue & indeed may reach chamber, but sanding outside is required too.
This combined batch product should not exist. 3 mistakes in one product.
But key-mistake is combining unfitting batches.
The best outcome would still be for Meyer-Audio to stand by their mistake and replace them.
Give an updated matched set,
Stop offloading your inventory onto customer when they pay for a premium product
Actually tighten down QC so such big margins do not happen, neither accept different size shells as one product.
And stop lying about manufacturing to dodge warranty & cause your e-tailer partners trouble.
When the real person that messed up is Meyer-Audio’s team;
Although e-tailer equally doing excuse switching due to B2B relationship & wants to keep near 50% of the item cost as a gift. No comment;
E-Tailer trouble for another day, but it is Meyer Audio that doesn’t stand to their products.
It was soo easy to just resolve it and forget, because you had a good product release streak.
- The cable is nice, bit heavy but nice.
- The tuning is well done. Slight gripe on the bass amount but its fiine. Fittings swap game.
- The sound spectrum is accurate and very suited for competitive gaming. Big +
- The designer does lovely hand-paint shells
, but has to eat the blame now too
Sadly the company & consumer support especially ~ failed.
QC failed too , but humans make mistakes.
They are soo competitive and i really want to keep them or even upgrade to 400$ version,
but this treatment is not ok~!
