I asked the exact same thing because i bought the Arya haha Welcome Bro you’re in the same predicament as iam.
Im thinking about buying Bifrost 2 but i dont want to spend too much money for now. The LP DAC should come out this month or next. Let’s see i guess it has a AKM4499 which should be good? But of course no EQ that was too expensive i think.
Yeah I think you would be just fine, just make sure the arya is balanced to the lp
Thanks so much for the replies
. Yup, I have a balanced cable for the Arya
My bad I meant to type Valhalla
This would mainly be for the t1 correct?
yes though I am considering ordering a ZMF headphone
I mean you have a lot of options imo, personally I’m not a fan of the valhalla. I might suggest you look into actually some of the MAD amps as those are pretty great and you can get good prices on them most likely, also wolf ear audio makes a pretty baller otl that is worth a look in canada. Also some of the space tech stuff too
I’ll take a look at Wolf Ear. I want to know more about the MAD amps but the among the 3, The Sidewinder, Mellowboy and Ear+ I’m having a hard time choosing cause I’m not sure what the differences in sound signature is
Generally I think the mellow boy would be what I would suggest going with for a zmf and a beyer t1.2 imo, I think that would give you the most flexibility in terms of sound since it can change it’s sonic signature a bit, and also I think that the beyers and zmf can respond very well to otl, the sidewinder and ear+ are going to be a bit more neutral and clean, I think the mellow boy would give you the coloration and sound you are after
Hey i just realized im an idiot. Not only ist the LP 817$ for me including shipping it’s 120Volt and i need a converter. Fuck.
Pretty sure the power thing is multi voltage? I know a few people using their lp in europe without issues but I don’t think they are using a transformer/converter
Really? lOl Monoprice wrote me i need a converter just now.
I read that here which contradicts what monoprice told me: https://www.head-fi.org/threads/monoprice-monolith-liquid-platinum-by-alex-cavalli.876406/page-25
I was about to ask you but you just answered it.
Puh at least something nice
Thanks
They prob mean you just need the right power cord cable, like an iec c13 to whatever plug style you use over there on your outlets
Mh he literally said this:
Neue Nachricht von: [monoprice.com])
Hello, I apologize for your inconvenience.
It is 120v. You will need a converter.
Thank you & Have a great day. Regards Shaf
But its k now i had this Forum to Help:D
I just looked the power brick on mine says 120-240V in, you’ll just need the right IEC to plug thing
Perfect thanks i have enough of those.
Bruh what is that response, did he even look at the product you were asking about lol?
I also asked some other things like that the price went down 2 days after and if i could somehow benefit from the discount with a store credit or something. And that im interested in the monolith Platinum dac.
But those Things went right over His head
I think you happened to get someone who is just is just completely done with his job lol
Just fyi went to Maple tree’s site. THey’re on vacation til september and wont be taking orders til then. I think I’ll be ordering their Mellow Boy and their switches When they open back up
