Any suggestions for better / bigger tips for the Moondrop Aria? Recently got a pair and the largest size is not quite big enough.
Although this isn’t the exact place to discuss an IEM set here, I suggest buying Final Type E tips and check product’s measurements to find your right size.
Alternative tips I also recommend are Spinfit CP100/145, Azla Sednaearfit (normal version), Radius Deep Mount
Sorry, I’m new here and totally missed that there is a specific group for IEM’s. I appreciate your reply and will move the conversation there.
No problemo, and welcome to HFGF!
Welcome to HFGF
Check this thread! Also, Azla tips have bigger sizes than normal, but you might not need it if you find your right ones!
Also, there’s the famous @Rikudou_Goku 's tip list/review:
https://docs.google.com/spreadsheets/u/0/d/1YNuslYM4CrhMPrOLofzTm4ei7HEfP8AI1zxswrMw2ho/htmlview#
I have used the Final series E and they are very similar to the stock tips. I think my go to so far has been the Spinfit CP100, but they have the thinnest silicone. I have some JVC Spiral Dots coming in this week, so I can finally test those out. The Dots have the largest opening, so I am curious if they sound different.
I didn’t like the Dekoni, or Comply, but my ear canals are small, and they fit tight on me, even at the smaller sizes. I think they work better for people who use bigger tips.
