Finally⦠And thanks for doing a side by side comparison with MEST ($1000) and Xenns UP ($700) which I donāt have the budget to experience! It really shows what different price brackets do to the IEMs. The MEST and Xenns UP definitely performed better in separation and resolution whereas the Aria has a bit of the āsournessā (veil?) albeit the relaxed signature. In terms of the Starfields, I canāt hear much difference tbh. However, after hearing the Aria, I really recommend comparing it with the Tin HIFI T4 and see how the resolution and tuning are different. No doubt the Aria is tuned beautifully, but with Tin T4 going for $70 on Drop sometimes, I wonder if the T4 will beat the Aria by a slight margin.
Thanks for this comparison!! This review is a full-blown experience, and perhaps itās just because I personally prefer a better resolution, I figured that I might be content with the IEMs I have atm. I tested your tracks with BLON BL-05s (foam tips), Tin T2 (silicon tips), Tin T4 (foam tips), and Koss KPH30i Clear (Yaxi pads). The results across these headphones are consistent across what Iāve said in the previous paragraph. What an experience!
*Sidenote: I think the BLON BL-05s are overly underestimated 'cos people tend to think that it should be similar to the original BL-05. NO, BIG NO. BL-05s are better tuned in every way, massive upgrade from the originals.
