oh, that is a big painā¦no way to export your presets so you have a backup that you can then import easily?
Sony comes to the rescue then.
(got the Xperia 5V a few months ago.)
I think itās possible with the desktop app which honestly Iāve just been too lazy to get around to checking out ![]()
Meanwhile I just took screenshots of all my EQ settings and manually remake them whenever an update nukes them. ![]()
This MUST be something the developers are aware that people do not likeā¦and they havent added it, despite the app being out for years???
Well like I said I think itās a part of the desktop app now. But being a developer myself, I get it⦠Thereās probably something very wrong with how EQ is stored in the core code for the mobile app and to fix it would require starting the code from scratch⦠![]()
Edit: but yeah theyāre aware of the EQ update bug for the mobile app
Aaa, the classic spaghetti code issue lol.
Damn Jamie went hard on it.
So:
Preamp: -5.0 dB
Filter 1: ON PK Fc 1400 Hz Gain -3.0 dB dB Q 0.80
Filter 2: ON PK Fc 5400 Hz Gain -3.0 dB Q 2.00
Filter 3: ON PK Fc 14000 Hz Gain -5.0 dB Q 2.0
I find it interesting that there are no bass adjustments with this
Yeah I see some graphs where the DSP has some different bass but that could be the aforementioned source doing some extra DSP on the USB output on top of the Moondrop cableās DSP. Or could just be reviewer prototype unit issues. But here we can see the EQ profile should be correct ![]()
Yeah Iām trying to buy one at some point but for now Iām just chilling out lol
Honestly quite surprised to see such low pinna from a crin iem.
Made a post on his Reddit concerning the massive difference in his FR vs all otherās FR:
https://www.reddit.com/r/inearfidelity/comments/1bvud09/moondrop_crinacle_dusk_fr/
Did Moondrop royally f*** something up or did he (Crinacle) stealth revise the target?
For what I understood you have to use the app only one time (if you donāt like the default profile of the dsp cable). After that you changed the sound profile you can uninstall the app.
Watch the video of Timmy (gizaudio) he explains what you can do in the case you break the cable.
Looking at these EQ numbers, the 14kHz really had to be killed by up to -10dB. The planar tweeter are doing their job too well.
Iām not familiar with DSP cables, but from what I understand is that they do essentially the same as parametric EQ. My question is, is it possible to recreate the exact sound through something like Wavelet or peace on PC? For me that makes the cable redundant unless it does something special.
I wonder if itās possible to accurately EQ the crin presets into my Blessing 3? Sorry, Iām a bit of a noob in this regard.
No, because the B3 has a different driver config (2DD + 4BA) while the Dusk 2 has 2 DD + 2 BA + 2 Planar.
